Bus Error Malfunction
Old Apr 24, 2019 | 07:02 PM
Bill71's Avatar
Bill71
Default Bus Error Malfunction
2016 Breakout FXSB
20 minute ride. Everything fine... 5 minutes into ride home, all warning lights on Speedo come on, LCD reads "Buserr", absolutely no hand controls working, no signals, no horn, trip button wont toggle, no hi beam, even the front brake lever wont activate brake lights.
Ran fine though... got it home. wouldnt shut off with Kill Switch. Turned off ignition switch, and it continued to run for about 30 secs then stalled.
With ignition switch off, the fuel pump randomly primes as if Im hitting the Run switch. Speedo is blank. No lights, no LCD.
Turn ignition switch on, and she wont crank over (no control functions), random lights randomly come on and off on Speedo.
Pulled Main fuse, waited 2 mins, re-installed.... same symptoms.
Multi meter on battery shows 12.54 volts ( everything off).
Cant pull codes ( no trip function).... Battery charger hooked up doesnt seem to help.
Anyone have any ideas?
Old Apr 24, 2019 | 08:28 PM
Vernal's Avatar
Vernal
From 2015 Touring ED Manual
Old May 2, 2019 | 01:09 AM
Buster217's Avatar
Buster217
If you haven't solved this yet, maybe this will help. The CANBUS is a serial data bus that connects to things all over the bike. Sensors, the ECM, BCM, switches, gauges, etc. It consists of two wires that go to all these devices. Probably something somewhere in the system is shorting or otherwise interfering with one of those two lines.
I would get the wiring diagram from the HD website or your service manual and trace the bus through the system. You can't do this to everything connected to the bus but you can disconnect some of the devices on the bus one at a time and see if the buserr goes away. You may be able to identify the culprit this way. If that doesn't work, try examining the CANBUS wires for damage like broken wires or chafed insulation.
Good luck. This can be a real hard problem to track down.
Edit: It would make sense to do a check of the wiring first, rather than unplugging things. At least every part of it you can inspect without taking things way apart. I guess I'd kinda do both things in parallel.
Old May 2, 2019 | 11:37 AM
Bill71's Avatar
Bill71
UPDATE:
Bought the EDM for my year... traced issue to faulty ABS ECU.
$523 out the door... still waiting for it to come in. Will install, then trailer bike to dealer for 1/2 HR Labor to map it.
Old May 5, 2019 | 04:47 PM
Bill71's Avatar
Bill71
UPDATE:
So the plots thickens.... as well as the expense.
Got the ABS ECU in, plugged it in and quickly tested everything... Ignition on, everything came back as expected, with just an ABS light on (which I figured since it still needed to be mapped).
next afternoon, put the rear tire back on , started it up to pull into trailer.... let the clutch out and she stalled... immediately all the symptoms came back, and would not crank over.
Brought it to dealer. They spent 3 hrs on it Saturday suspecting a Re-flash would probably straighten it out, and came back reporting they're unable to get the bike to communicate with HD ET.
Serv Mgr shaking his head saying "This isnt good.... Ive never seen any electrical issue act like this"
So... now we're awaiting a phone call to tell me the bad news. I suspect it'll be another week or so. They are scheduling out til May 15th, so Im not expecting to get this thing back any time soon.
Old May 14, 2023 | 03:43 PM
SW74's Avatar
SW74
3rd Gear
I'm curios to know what ended up being the final repair on this bus error Breakout ?
Old May 14, 2023 | 05:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The OP has not been active since his last post, check the date...
Old May 14, 2023 | 08:14 PM
SW74's Avatar
SW74
3rd Gear
Thanks for your insight. It appears he also had a thread on V-Twin Forum that year, says 2 dealers had a hard time resolving his concern. Says they replaced 2 ABS ECU's, 1 BCM, 2 ECM's, 1 RHCM, 1 LHCM, main wire harness and an aftermarket Accel coil pack before things were up and running again.
Fine09
Jul 21, 2017 07:40 AM
Nova Sportster
Electrical/Lighting/Alarm
May 5, 2013 08:24 PM
r00tkanal
May 3, 2013 03:41 PM
Greco_Superglide
Apr 30, 2011 12:51 PM
jp1212pc
Jun 4, 2008 02:52 AM
