Adjustable pushrod advantages
Old Apr 17, 2017 | 11:01 AM
  #31
cvaria's Avatar
cvaria
As far as added weight.... not sure it's really that big of a deal:
https://www.hdforums.com/forum/showp...&postcount=386
stockness
s&sness
stories of adjustables being heavy and weigh as much as 3 stock rods....
Old Apr 17, 2017 | 05:10 PM
  #32
roussfam's Avatar
roussfam
Originally Posted by dan89flstc
there is no need for adjustable pushrods on an engine with hydraulic lifters.
I keep reading the one about making cam swaps easier, seriously; how many cam swaps are you going to do?
x2 imho
Old Apr 17, 2017 | 05:28 PM
  #33
Jackie Paper's Avatar
Jackie Paper
If your mod does not require them, keep it simple. Do the extra cost/labor for valve cover gaskets and tank removal. Tin men push them so that can cut time from an installation. Then chop off the original with bolt cutters. Hopefully, no shards of metal fall in. Hopeful, adjustable don't come loose. Been round and round on whether to us Loctite or not (that fine thread should not come loose if tighten correctly). Hopefully, they set them correctly in the mid range of the hydraulic plunger. ALL JUST MY OPINION.
Pretty cool how cvaria has weighted them Only thing important to me would be the rod itself. I would have never guessed the adjustable is only 3 grams heavier. That is only .10 of an ounce. So that is not big deal. That larger tube must be a thinner wall.
Old Apr 18, 2017 | 05:32 PM
  #34
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Hillsidecycle.com
The adjustability, quiet engine operation, and positive lifter load, trumps any negligible weight differences, every time.
Scott
Positive lifter load?
The load between the rocker arm and the lifter is exactly the same, whether adjustable or fixed length pushrod is used.
Old Apr 18, 2017 | 07:33 PM
  #35
roussfam's Avatar
roussfam
And we're off.....
Old Jan 12, 2023 | 12:16 PM
  #36
OutlawFC222's Avatar
OutlawFC222
Originally Posted by Madnss
I've always used solid pushrods, if I need to tear down I do not care if I don't have adjustables. Smith bros will make high quality solid rods for cheap. I now run adjustables because I switched to hydosolid lifters. But, this is on an xl and they don't have collapsible covers from the factory. And I didn't want to spend the cash on adjustables, and a collapsible kit.
I use Smith bros pushrods in both of our 4k hp outlaw funnycars and if they'll hold up to that then they certainly should hold up to a tc that will never see 9k rpm lol.
Old Jan 12, 2023 | 05:32 PM
  #37
martinj's Avatar
martinj
Five year old thread.....
Old Jan 13, 2023 | 08:07 AM
  #38
bustert's Avatar
bustert
i run the rivera adjustable p/r's and colony collapsible tubes
the reason is i also run lifter spacers. the setup is like running solid lifters.
advantage:
no worries about pump up or collapse
no worries on start up
i run the limit on the rpm scale
i run just enough spacing to quiet the valve train. 1/32=.03125 /6 (hex flat)=.0052 X 4 (flats)= .0208 x 1.65 arm ratio = .034 stem clearance. but the hydraulics picks this up.
also note: running solid on a hyd cam changes the way the cam functions and can HURT or HELP depending upon grind profile. on my set up it is a positive.
chiefy305
Nov 29, 2020 08:09 AM
rydahog
Dec 7, 2017 04:44 PM
RUBI-VET
Jul 21, 2016 09:32 AM
steelpony16
Aug 7, 2013 06:25 AM
Scramboogie
Exhaust System Topics
Dec 4, 2008 10:54 AM
