My first break down, sorta.
Old Nov 16, 2015 | 04:27 PM
  #61
Joe_G's Avatar
Joe_G
Turn off the run switch. Will it still crank?
Old Nov 16, 2015 | 04:44 PM
  #62
junglejoe's Avatar
junglejoe
No, it wont do anything. WTH? Ok, so the coil wire was not hot before I took all the ignition module out of the nose cone and all the wires off the coil , Schex had me guessing about the kill switch, so I put it back together and it fires up immediately. Doesn't make any sense.
There is no bare wires any where on the bike, I made sure of that. But something is defiantly going on weird.
Old Nov 16, 2015 | 04:46 PM
  #63
Joe_G's Avatar
Joe_G
I feel like a broken record. Trace that white wire. Make sure it's not shorting out against the cone, then trace it on back to where it goes. That wire is your problem.
Old Nov 16, 2015 | 04:54 PM
  #64
junglejoe's Avatar
junglejoe
It must have been Joe because I traced that wire back to were it starts and where it ends, nothing is bare anywhere. It is a tight fit in that nose cone and the wires are in a pretty good bind. It defiantly was not hot before I took the ignition off the bike. I simple put it back together and it immediately fires up. BUT, I'm going to triple check the wires again.. just been working to much and my brain isn't thinking clearly sometimes.
Old Nov 16, 2015 | 05:01 PM
  #65
Joe_G's Avatar
Joe_G
We've all been there, that's the beauty of these forums, you can post up a problem and get some suggestions from a stranger who may have dealt with it before!
Keep us posted buddy. I hope you find a little short in that white wire or perhaps it came unhooked and you reseated the connection..something simple like that.
But also think back to when you backed it out of the garage when it didn't start...did you catch some kid toys backing out that may have snagged that wire under the bike?
I subscribe to Occam's Razor - the simplest solution is usually the right solution.
Old Nov 17, 2015 | 06:32 AM
  #66
junglejoe's Avatar
junglejoe
No, I put all my toys up before I backed it out of the garage..LOL. I'm thinking it had something to do with the wires in the nose cone, where it comes up through the hole in the bottom. It's a very tight fit in there and those wires are hella bent in a "U" and "S" shape.. I don't want to take it on a hot lap and get away from the house and be stranded. Something is wrong and I'll find it before I take it out of the garage.
Old Nov 17, 2015 | 07:03 AM
  #67
Joe_G's Avatar
Joe_G
That would be the most likely place I'd think. That's where I'd start my search, possibly the white wire is partially broken or shorting out there. Another place would be under the seat, any pinch point.
When I diagnose something like this, I always like to think it worked yesterday, today it doesn't, what changed between today and yesterday. Did you remove the seat or tank or fool with the handlebars or anything before this happened?
Old Nov 17, 2015 | 07:17 AM
  #68
Schex's Avatar
Schex
No lights on the module can only be three things,
1) no power to the white wire
2) module not making a ground to the nosecone
3) bad module
Originally Posted by Schex3x
I had a strange ignition issue a while back, started running erratic, then no start, no lights on the dynatek module, I scraped and wiped with brakeclean the mounting areas for the module, which is also the ground for the module, it didn't look to be dirty or have a bad connection, but solved the problem.
Old Dec 14, 2015 | 06:22 AM
  #69
junglejoe's Avatar
junglejoe
SOB!! Went to fire it up again after it's been sitting couple weeks.. no fire and no red LED light on the module. The white hot wire has power. Last time it did this , I took everything apart and I think it was Schex3x had me second guessing myself, so I put the ignition back on and into the nosecone, and it fired immediately. So technically, I didn't fix it because all I done was reconnect everything. Seems to me to be something as far as the module is going out or a grounding issue into the nose cone..
Old Dec 14, 2015 | 06:25 AM
  #70
junglejoe's Avatar
junglejoe
No, just went and rode it all over the place like I always do, got back to the house,put it in the garage. Couple weeks went by, went to start it, no fire.
astark
EVO
Aug 2, 2013 12:29 AM
RidemyEVO
EVO
11
Jun 8, 2011 03:03 AM
hdbeggs
Feb 14, 2011 02:22 PM
jizquie560@aol.com
Aug 12, 2009 02:19 PM
redtruck
Shovelhead
Jun 22, 2008 10:24 PM
