Found my front mount issue
Old Jul 22, 2021 | 01:17 PM
Garageking's Avatar
Garageking
Default Found my front mount issue
Been putting off installing my STA-BO front mount awhile, engine really moving a lot , and i "felt" a change in the noises when i was braking...
I set the bike up and remove the regulator and find the remains of one engine-side bolt for the mount bracket. The left side one is loose, and the mount was sagging enough I think the bolt could contact the frame under braking.
Found exact match for shiny hardware at Bigstore last night.
Looks like i have the revised HD mount on this bike (prolly who left the bolts in disrepair) and it looks decent, a little slanted. Also have the STA-BO version new.
Gotta decide which to run with.
Old Jul 22, 2021 | 02:07 PM
mike131's Avatar
mike131
So there was no front rubber mount left in the bike at all??
Old Jul 22, 2021 | 02:25 PM
Dr.Hess's Avatar
Dr.Hess
Looks like one bolt was snapped off an the other one was loose.
Old Jul 22, 2021 | 02:41 PM
Garageking's Avatar
Garageking
No, my bike had the 79D later mount. 98 FLHRCI.
I am comparing it to the STA-BO. My HD 79D looks pretty good.
Cant find any first hand info on installing the STA-BO, and i wonder about the conical shape of lower half. The Stock mounts use that big washer, same diameter as rubber.
Im thinking since my issue was broken hardware, i may stick with the HD mount and BIG washer until i know more. Pic shows STA-BO sitting on washer
Old Jul 22, 2021 | 03:40 PM
t150vej's Avatar
t150vej
I've never run a StaBo mount but what I've heard and read, they will give you more vibes. The -79D is a good mount. Mushroom up and be sure to align the mount, washer and thru bolt by the book and you'll be happy.
Old Jul 22, 2021 | 06:55 PM
WP50's Avatar
WP50
I think t150vej has a good idea.
No experience with a Stabo but the OEM is a good mount
WP
Old Jul 22, 2021 | 08:49 PM
Dano523's Avatar
Dano523
HD factory updated mount is the way to go, unless you are changing out the swingarm bushing to the stabo kit as well.
Hence the stabo swing arm bushing kit is going to cause more motor vibration to begin with, and what you will pick at an increase with the poly motor mount, will not be that noticeable.
Also, before you tighten every thing down, check your rear tire/engine alignment to get that correct with the mount end links,, then you can finish tightening down the front motor mount hardware.
Old Jul 22, 2021 | 11:38 PM
Schex's Avatar
Schex
This supposed to be the company that made the old Harley mounts,
Barry Controls, https://novibration.com/
507-3NS is what Harley used, there's two softer versions 507-2NS, and 507-1NS,
Hit snubbing washer in the blue downloads box, to order the washer
about $40 shipped
https://novibration.com/products/bon...rtfolioCats=29
Old Jul 23, 2021 | 10:40 AM
Garageking's Avatar
Garageking
Cleaned and reinstalled HD mount with a bit of white lithium grease, locktite blue, engine much more secure, gonna check alignment today but it rides fine as frog hair
Fatboy16S
Sep 5, 2022 02:02 AM
Matty_d
Jun 16, 2021 05:08 PM
Bodacious MC
Mar 28, 2019 01:02 PM
cajun1957a
Mar 3, 2017 03:19 PM
txultra
Apr 8, 2006 03:19 PM
