getting ready to "push the button"
Old Jan 20, 2013 | 11:30 AM
  #161
traildog's Avatar
traildog
got her drained by using the front cross tube. Damn what a mess....
Old Jan 20, 2013 | 11:37 AM
  #162
traildog's Avatar
traildog
ok, tank off. checking connections and ignition.
Old Jan 20, 2013 | 11:49 AM
  #163
traildog's Avatar
traildog
compression exits hole twice as much as plug fires. Is that right?
Old Jan 20, 2013 | 12:10 PM
  #164
traildog's Avatar
traildog
OK, I just ran a wire from coil positve to battery positive and cranked her. Spark plugs are sparking twice as much. Bad coil?
Old Jan 20, 2013 | 12:17 PM
  #165
bluharley's Avatar
bluharley
Didn't someone say you could switch that coil to a dual fire?
Old Jan 20, 2013 | 12:23 PM
  #166
traildog's Avatar
traildog
There's a switch on the module that can be turned to recognize a single or dual fire coil.
Are you thinking I can just use 1 "side" of the coil?
Old Jan 20, 2013 | 12:35 PM
  #167
bluharley's Avatar
bluharley
I'm thinking if you can switch to a dual fire, you would solve half the timing debate! But I know nothing, so need to hear from an expert!
Old Jan 20, 2013 | 12:46 PM
  #168
traildog's Avatar
traildog
I think it might be the coil. she was having slow starting probs before the rebuild.
When I did the jumper wire trick, the plugs fired twice as much and very brightly.
Old Jan 20, 2013 | 12:49 PM
  #169
Rootro's Avatar
Rootro
Time to take it to an experienced tech, you tried. Just pay the 3 hours of labor cost and a shop, before you break something else.
Old Jan 20, 2013 | 12:52 PM
  #170
bluharley's Avatar
bluharley
It sounds like you just turned it into a dual fire. Firing twice as much just means both plugs fire at the same time instead of alternating. But with your lifters and such as they are, I don't want to be a part of your valves banging into your pistons! I don't know if you can just switch to dual fire with your setup.
