getting ready to "push the button"
Old Jan 20, 2013 | 01:08 PM
  #171
Schex's Avatar
Schex
Put plugs in and start it, that module will fire dual fire until it starts and syncs to single fire. Should have enough gas in carb to crank it.
Old Jan 20, 2013 | 01:25 PM
  #172
traildog's Avatar
traildog
So, after that, if she starts, what needs to be done?
Old Jan 20, 2013 | 01:32 PM
  #173
bluharley's Avatar
bluharley
put the tank on and go for a ride!
Old Jan 20, 2013 | 01:36 PM
  #174
Schex's Avatar
Schex
Run it for 30 seconds or till carb runs out of gas, which ever comes first, then replace tank while it cools down, then do it again.
I been checking in when we stop, beautiful riding day here, in New Orleans right now having lunch and a beer.
Not teasing, just incentive to get her done!
Old Jan 20, 2013 | 01:51 PM
  #175
traildog's Avatar
traildog
did it. no start
Old Jan 20, 2013 | 01:52 PM
  #176
traildog's Avatar
traildog
That's a bunch of horse hockey! I should be riding today too! 25 degrees and SUNNY.
Old Jan 20, 2013 | 02:04 PM
  #177
bluharley's Avatar
bluharley
LOL! Balmy! The sun should melt the ice and snow off the road for ya, at least in spots.
Old Jan 20, 2013 | 02:20 PM
  #178
V-Twins & Bowties's Avatar
V-Twins & Bowties
Originally Posted by traildog
OK, answer this one. I disconected the fuel line from the petcock, turned the fuel back on, and nothing comes out. Is that normal or is this my no start problem?
This could be the whole problem. There is no fuel / not enough fuel in carb. You need to insure fuel is being delivered to the engine. Then try to start it.
Old Jan 20, 2013 | 02:44 PM
  #179
traildog's Avatar
traildog
Earlier in the thread, someone said, the fuel won't drain out because the system is Vacuum operated.
Old Jan 20, 2013 | 02:46 PM
  #180
lownslow's Avatar
lownslow
He has a vacuum operated petcock which open when engine turns over. He also stated in a previous post that fuel was squirting out of the accelerator pump. If you listen to the video, it doesn't even cough. I believe it's not firing correctly or firing at the wrong time. Good compression, fuel delivered and nothing. You light that compressed fuel/air mixture and something's gonna happen.
