getting ready to "push the button"
Old Jan 20, 2013 | 02:56 PM
  #181
bluharley's Avatar
bluharley
How do you tell if it's vac operated? There must be a vac line going to the petcock, should there? I don't know about these new fangled things, I like my '88, simple.
Old Jan 20, 2013 | 02:58 PM
  #182
V-Twins & Bowties's Avatar
V-Twins & Bowties
I understand it's a vacuum operated petcock. But just cranking the engine won't in my opinion open the petcock. Can't hurt to try putting an outside vacuum on the petcock to rule out this possible problem. Besides, all this cranking those plugs should be soaked if the fuel is flowing.
  #183
traildog's Avatar
traildog
I'm thinking coil. But, can they go bad slowly, or do they fail all at once?
Old Jan 20, 2013 | 02:59 PM
  #184
V-Twins & Bowties
Humor me please. Try it out. Unless those plugs are soak-n-wet then disregard.
Old Jan 20, 2013 | 03:02 PM
  #185
bluharley's Avatar
bluharley
Do all '95 FLHTP have vac operated petcock? How do you tell? Must be a vac line going to it, right?
Double post, my bad..
Old Jan 20, 2013 | 03:03 PM
  #186
traildog's Avatar
traildog
That's one thing that has me wondering. I'm not getting the "flooded" smell, the plugs smell like gas but aren't wet.
Old Jan 20, 2013 | 03:05 PM
  #187
V-Twins & Bowties
Then there is not enough fuel in her. Thats my story and I'm sticking to it.
Old Jan 20, 2013 | 03:08 PM
  #188
traildog's Avatar
traildog
Yep, plugged into the back of the petcock.
Old Jan 20, 2013 | 03:09 PM
  #189
traildog's Avatar
traildog
I drained 3 frikin gallons.....how much does she need to run?
Oh, you probably mean fuel to the plugs......my bad........
Old Jan 20, 2013 | 03:13 PM
  #190
lownslow's Avatar
lownslow
It doesn't take much to open the petcock. When I drain my tank I use a brake vac like the one in the pic. No more than 10-12 in. HG, you don't want to damage the diaphragm.
