- Motor shutting off
- New TW 222 cams in 07 wideglide
- Twin Cam 88B to 107 Build Instructions
- 2013 FLS oil tank "empty" after a few days of standing still
- 2007 Electra Glide Classic (Unknown Issue)
- Need help. Sporadic engine problem
- I reinstalled my 255 cams today
- Extended warranty/ crank failure
- Do i need a tune?
- 96” upgrades
- altenater plug for 03'fxd
- 2002 Deuce engine?????
- Non-SE cams with a SE117 kit?
- Help with codes on 99 road king
- Top end noise?
- Need help with engine serial number
- How Much Tension does a Cam Chain Need??
- Horizontal Cylinder Score
- 88 cubes throwing in the Towel
- Fuel Moto kits
- Twin Cam External breather and vented dipstick possiblity?
- 2003 FLHTCUI Electrical Issues
- Primary noise/damage
- Dip stick blows out 2001 88 Twin Cam Road King
- Disconnecting compression release ? 2014 Ultra
- Piston search assistance
- 2006 88TCi Case Bolt Oil Leak
- Cam Chain Tensioner Removal Tool
- How do I test this Test ignition coil
- Air/fuel adjustment screw
- Advice on cam upgrade tc 103?
- It was supposed to be just an oil change
- Oil Puking Issue
- primary noise same deluxe more problems...
- Cam Chest Questions
- Crank sensor issues
- Recommended tuner for S&S 509 cams ?
- Timkin bearings
- 07 Ultra. 11 miles per oz of oil. Read on
- Cam tensioner help needed
- Question on 107 build
- Primary oil consumption
- Newbie help - crank but no start
- Rocker arm and valve problem
- INstalling Hybrid Cam Plate on 03 RKC
- 2011 FXDC 96ci CAM ONLY upgrade
- 2010 Extremely High Idle
- 103" with 585 tuning problems
- Tryin to find a thread
- can you check crank runout out of the crankcase?
- Cam recommended for 97”
- How do my spark plugs look?
- Blackcherry Pearl
- Carbed engine dies
- Planning Andrews cam upgrade, other things worth doing while inside?
- Learning about my Twin Cam
- 04 fit 06
- S&S583 vs S&SMR103?
- How likely for a 03 88 to have a case leak?
- Air Breather Question
- Lifters, which ones? Part # ?
- Grand Rapids service
- mystery motor on 05 deluxe?
- Purge Oil Change
- suitable freeway cruising rpms and speed
- seeking cam for 103 to 110 ?
- Check those tensioners now!
- Hard Start After AutoTune
- Twincam 124 build
- Softail coming home tomorrow
- 06 88 tc
- Going for the 98 big bore but got some Questions
- Needing ideas
- Reputable Tuners Within 3 Hours of Cincinnati?
- Umbrella Valve
- Break In Requirements
- white spark plugs
- 124” s&s upgrade
- 88 cylinder heads
- Question about 96" to 103" BB upgrade?
- Incorrect VIN report on 2013 Twin Cam?
- Which Ignition set up for a 2002 carbed fatboy? Doing cams and 97" kit
- 120R Serial number
- 2012 Ultra 103 intermittent decel clatter noise
- 95'' S&S 510 Cam Upgrade Question
- 103 CI Rocker arm replacement (2012)
- 88A motor direct mount??
- Cv performance woes
- Easy Start Durability
- Screamin eagle 94648-08
- Disabling ACR's...
- Feuling Hydraulic Cam Tensioner Kit
- 2005 road king efi (delphi) intake o-ring part number
- Twin Cam A Engine Stand and tools?
- Twin Cam Spring Tensioners
- 2004 FLHRCI 1550 Upgrades
- Inner Chaincase Adhesive?
- 2015 FLHTP...Very Noisey when hot..not cold
- 2001 electra stuck in learn mode
- runout on a stock twin cam crank
- 107 Plus Cams
- 2008 Harley FXDC - Rocker Box Gasket Leak
- HELP 110 for 09 FLTRSE3
- Engine swap
- 2010 wide glide needs cams
- Hesitation and sputtering on acceleration
- 107" Zippers Muscle Build
- Screeching on startup
- ID this build?
- Black plastic pieces found in oil pump
- '03 TC88 winter checkup (previously t 26 torx?)
- Advice going big on a TC88 and shop suggestions
- need help with build
- Oil Cooler question
- S & S 509g Complete Camchest Upgrade
- 103 engine heat question....
- 2016 FLHTP what cam is installed
- 103 with P1353 and P1356 codes
- Cost of boring cylinders
- TPS Maintenance
- 2009 FXDC oil use
- Baffle loose
- Pulling codes on a 2001 FXD
- Tension to gear
- Slip-on exhaust
- t 26 torx???
- 103 Cam Timing
- Upgraded Oil Pump
- Motor Mount Screws
- Piston Condition - TC88
- Can you swap charging systems on 88 twin cam
- 2003 TC88 Lower End Build
- TTS-100 CAM, any good for a ultra
- SE Stage 4 tire shredder kit for 103
- when to change valve springs
- 2000 Ultra...Spark plug question.
- Long-term issues on high RPM driving?
- bouncing rpm’s
- Flhx high rpm on start up
- “Spare parts 103” build with dyno charts
- See any issue?
- 06 Electra Glide Classic, 4000 miles - what to look/fair price? for?
- 2002 FLHTCUI tranny seal leaking
- Increase cubic inches?
- Overheating Harley 😰
- 2005 FLHT rusty and crusty
- 2005 FLHT front head exhaust studs
- Best stage 4 spark plugs and gap?
- TC88 Oil Consumption
- Your thoughts on the Woods TW222 cams
- Point of Diminished Returns?
- 07 flht spitting and coughing thru throttle body
- 1999 Lowrider Advice
- 1995 dyna fxdl factory jets
- Burning oil
- 2010 Wide Glide stage 4
- How to test a delphi coil 31743-01
- 110 stops running
- Backfire
- Loud banging (like a bad comp) but all the time.
- Removing exhaust header bolts
- Twincam - DIY inner cam bearing tool
- ‘04 RK Vibration worse after lower engine mount?
- New 100ci s&s bigbore problem
- Octane Booster and Higher Octane Fuels
- Error codes 1999 road king classic
- Y2K RK EFI Cam Chest Work
- 2007 twin cam poping intake and exhaust
- Updated to new compensator
- Cycle shack slip on for 2004 fxstb
- 07 ultra idle
- Fuel pump and sending unit question
- Street glide 2010 - headers temperature
- 03 flhrsei2 charging sytem rotor shim.
- No oil pressure on 2006 Streetglide FLHX
- Cam Chain Tensioners????
- Broken compensator bolt
- oil dipstick cap
- 2015 Street bob stage IV questions.
- 2007 softail 96cI B modle engine oil foaming?
- Trans side cover
- Valve Train, Lifter Noise Gone?
- 2012 103 stock head port design
- First bike ever
- 2001 FXSTI - TC88-B Lifter noise
- Crankcase pressure/top end noise.
- Rocker Lockers
- 09 103" FLHTCU craps the bed
- Question about lifter Tick
- 103 2into1 pipe
- Spark plug hole cross thread?
- Old se 95 big bore kit
- 96”internally balanced bottom end
- Oil capacities
- 103 spark plugs
- Will an 88 fit in a dyna frame
- Both head gaskets blown???
- SEVERE engine vibration
- Total brake failure
- Bike died and won’t start
- Firing on 1 cylinder
- S&s heads valve spring lift to much.
- 88" S.E-203 cams F.I
- High Volume Oil Pump Info Needed
- Gear Driven vs Stock Cams
- 2004 flhrci
- Rocker breather kit replacement issue. Help!
- FXDLS Front Master Cylinder Rebuild
- Hillbilly Ram Air
- 07 road king running hot
- Twin cam 88A
- 2015 Ultra Timing chain area noise
- 2010 103 in a 06 wide glide???
- Stecklers
- 2008 FLHTCUI unknown knock around engine after rolling in gear in reverse
- Hot Starting Fault
- Engine Temps
- Rebuild Hell
- 2017 Twin Cam engine in 2001 Road King
- dual fire/single fire..do I have this right?
- 08 Road King won't start
- Twin Cam Softail 6 speed in 5 speed frame?
- S&S roller vs non roller rocker arms
- 2005TC88 in 2001 Road King?
- 2000 heritage with sudden vibration
- 96 CI to ??
- Ping
- Slight knock coming from primary
- 1999 M/M EFI tank fitting thread size
- Oil pressure
- 1999 FHLRCI Throttle Sensor Hunt
- Noise from the primary side
- Is this normal?
- Going crazy learning cams... help please
- 103 high compression stage 4
- looking into cams, again
- Camshoe changeout 72000 miles
- SE585 Cam experience
- Dyna trans compatible with twin cam b?
- Scrap it or Sell it? - Blown '09 96 in Twin Cam
- 2001 Springer Softail
- 06 Street Glide motor
- Online parts finder sites like Ronnies not working anymore?
- One noisy lifter after cam install
- 2007 compensator
- Twin Cam vs M8
- Primary Locking Tool
- 2000 heritage
- 103 to 110 Conversion or not
