PDA
View Full Version : Twin Cam Motors
Pages : [1] 2 3 4 5
  1. gear drive cams installed
  2. Poor boy tuning
  3. Stator Wire Grommet
  4. Inner cam bearings
  5. Resetting the head in the proper position after removal
  6. Nightmare TC88 Ticking Part 2
  7. Nightmare TC88 ticking
  8. Metallic motor sound?
  9. twin cam heads
  10. How do my cylinders look?
  11. Fuel Injector Cleaner
  12. Brand New 96 kit leaking
  13. 103 heads
  14. Stock 96 - Rockerbox Gaskets - What else?
  15. Reversion
  16. Bad screws
  17. Throttle body / backplate gap
  18. Early S&S T-124HC 640cams
  19. ?
  20. Compression test
  21. Oil cooler adaptor question
  22. 103 TC Swap
  23. T/C engine serial
  24. Chris Rivas Rocket Cams
  25. Twin Cam 88 - Questions on a Build I am Starting
  26. S&S flywheels
  27. What are peoples thoughts on this upgraded Twinkie....
  28. Need Y'all to tug me back from the edge! (Not really)
  29. Twin Cam bearings.
  30. Engine oil flow through filter ( time)
  31. twin cam trike
  32. TC 117" Big Bore...
  33. Andrews 216324 Pinion Shaft Sprocket
  34. New TC88 owner
  35. Can we save this 88?
  36. ISO outer cam drive conversion from chain to gear.
  37. Access the rockers or cut the pushrods?
  38. FXDL 2002 display output engine temperature sensor
  39. TC88 chain tensioners
  40. Timken conversion ?
  41. TC96 Paranoia
  42. 4° advance on stock 103 HO cams
  43. Gear drive only cam plate with a chain?
  44. Ever heard this b4?
  45. Oil Dipstick Blowing Out
  46. 650 lift
  47. HO 103 cams in the standard 103
  48. Help me with my twin cam build
  49. Oil filter burst spurting oil
  50. 2012 street glide
  51. TC88 Cam Chain Tensioner Replacement
  52. Twin Cam 96 Ticking Sound Traced to Exhaust Vibration"
  53. Oil leak
  54. Twin cam intake manifold question
  55. Buying a 2011 S.G with 53400 miles with rebuild cam chest, what else do i need to look out for ?
  56. 2002 harley fat boy
  57. What motor do I have?
  58. Cam suggestions
  59. Engine Swap
  60. Fault codes p0151/0132
  61. 99 Twin Cam Push Rods
  62. 95" throttle body size?
  63. Power vision counting knocks
  64. Pushrods rubbing?
  65. Compensator question
  66. engine id help for new custom build
  67. Thrashing AR dogball baffles?
  68. TC88 o-ring size
  69. 1-10, how bad do these look?
  70. bearings part number
  71. Rebuild 07 EGC with 125000 miles
  72. Engine back pressure
  73. Coil Bad ?
  74. 05 twincam noise
  75. Cam bearing puller/installer
  76. Pushrod adjustment
  77. tach wiring has anyone ever set one of these up?
  78. 2005 Softail cam tensioner opinions
  79. 2002 flhrci Road King build fine tuning question
  80. Tapping/knock on first startup after winter
  81. 88 in. cyl on 96in. engine
  82. Did the oil analysis about 4000 miles ago
  83. 2017 Fatboy head bolt size
  84. 05 twin cam heads with 06 throttle body
  85. Screamin Eagle Cam Tensioners
  86. Motor
  87. Normal oil pressure
  88. Special tools needed to R&R Dyna engine
  89. Performance
  90. High idle at 5000 all the time
  91. New Primary Rattle/Noise
  92. External oil cooler...
  93. 96" TC head porting.
  94. 2000 Night Train recommendations for cam chain tensioners?
  95. High oil pressure
  96. S&S, SE, or Feuling?
  97. 2004 Harley Road King knocking sound
  98. New lifters??
  99. Hydraulic Tensioner Shoe Groove - 2007 103
  100. TC88 jackhaft issue OEM part#OEM60647-94 will not seat right
  101. Vibration
  102. Forged Rocker Plates 17675-01b...
  103. Flywheel up and down movement.
  104. 2002 TC88 Adj Pushrods Question
  105. Roller Rockers
  106. More compression please
  107. Se251 equivalent
  108. 2001 Harley electra glide standard carburated running issue
  109. 2003 98" build problem.
  110. FLHTI 2004 98” builds
  111. 2005 twin cam pushrod
  112. 103 years
  113. Engine noise
  114. 01 Softail Deuce - Won't start when warm
  115. Need help with diagnosis/repair
  116. S&S pistons...cam suggestions
  117. Se 716925-02B replacement valves
  118. 110 cams
  119. Changing lifters in 2011 110 Help
  120. 01 softail carb, rear cylinder acting funny
  121. 110 kits
  122. 05 Fatboy rocker breather
  123. 2007 117 cvo motor swapping into 2007 Electra glide
  124. Replace Voltage Regulator?
  125. 01 Softail Deuce FI: hesitation accelerating / wont start sometimes
  126. 110 to 117 Needs SE Tunner?
  127. Spewing oil from TB
  128. Big bore gaskets
  129. Cam choice
  130. Advise on build
  131. TC88 oil change
  132. Undiagnosable Front Cylinder noise.
  133. More Power
  134. 2006 Engine won’t rev past 4000rpm
  135. TC88: working on the Cam Chest for the first time
  136. Dyna Vs Touring 103
  137. 2006 up crank in early Twin Cam
  138. Rattle on right side of motor 04 softail
  139. Needs some help please
  140. Twin cam 103 ran great and then started missing and sneezing
  141. 2005 Electra Glide Rear Rocker Box/Cylinder Removal
  142. Reliable 120/130 motor
  143. Valve spring noise
  144. Strange problem with my TC88
  145. Time for a fresh build!
  146. 2008 roadglide
  147. Rocker Box Gaskets Still Leak
  148. 2001 Road King, Slight increase in Vibration
  149. Motor swap
  150. Rebuilt Fuel tank quick disconnect. Now won't run
  151. Piston ring gap orientation
  152. 5 speed TC won’t get a gear any help appr
  153. 2003 tensioner check - 3 cap cover 8-32 snapped
  154. Oil leaking and can’t find the culprit
  155. Petcock vacuum line to mikuni hsr 42mm
  156. Upgrade Twin cam heads: Recomended valve size
  157. 88ci to a 103
  158. Engine drain plug shavings
  159. TC88 After the tensioners self distruct, now what ?
  160. 2002 Electra Glide Tensioners cam plate upgrade???
  161. Retrofit 2007 cam hydraulic plate into a 2004 twin cam ?
  162. Small Oil Leak: 05 Deluxe
  163. Hitch pitched noise, gets more intense when accelerating
  164. Tensioners in, or out of riding season
  165. new cams
  166. Twin cam power vison all the sudden started to idle weird
  167. 2002 Road King advice
  168. TC88 2003 FXDL wriring primary
  169. 2001 twin cam ingition computer obsolete
  170. Oil pump alignment necessary?
  171. Rear Cam Bearing Change
  172. S&S reed valve for 124TC build
  173. Tensioners …… again
  174. lifters and push rods
  175. Exhaust Flange Nut - STUBBORN!
  176. Chrome Tappet Lifter Block Accent Cover
  177. Lifter travel limiters
  178. About to do CYCO Tensioners install, just noticed...
  179. Really dumb question about 2 cams in the motor
  180. Annoying newbie 124 build questions
  181. That darn bolt....
  182. New member-dad gave me his 2016 wideglide, fm 107 bb kit needs finished
  183. Best resources to learn about all the parts of the twin cam motor and how they work.
  184. Push Rods and Cam Tensioner parts list: 05 Deluxe 88
  185. What would it take to use a 103 motor in an '01 Ultra Classic?
  186. Does a 96 shake as much as a 103?
  187. Used Purchase: Dealer Inspection
  188. Check Engine light. No codes?
  189. 95 inch big bore break in
  190. 2002 TC88 // bore to 95" or 98" S&S kit ?
  191. Flhxse3 street glide cvo with 110ci engine-where to get manual
  192. 2015-SG-CVO help please
  193. anyone know how to ID cams in an unknown engine?
  194. 96-103-110 wrist pin OD
  195. Help!
  196. ‘06 TC88 with head breather ports blocked !
  197. Build Twin Cam Motor from scratch
  198. S&S Gear Drive Cams Upgrade
  199. Oil Tank Sight Glass?
  200. Looking at my first Twin Cam. Any advice?
  201. Rebuilding a used engine
  202. Stock vs billet cam plate
  203. Cam for 110 kit
  204. HD Dyna Street Bob 06 (88ci)
  205. Twin Cam Rocker Arm Side Clearances
  206. 2006 Softail Springer with TC88B
  207. Mild 117 build cam
  208. 96 ci noise at 2500 rpm
  209. Anyone got a used 99-2004 secondary chain tensioner?
  210. From 50mm to 58mm TB and Power Vision
  211. 2002 harley fat boy
  212. Looking to buy a twin cam
  213. Don't Know What This Is
  214. 2016 FLHXS 103 to 110 Upgrade - Stock Cylinder Heads vs Ported and Polished
  215. EZ-Pushrod Came Loose - Now What?
  216. Leak down questions
  217. Lifters for 650 high lift valve springs?
  218. 2 part epoxy
  219. Twincam ignition
  220. Zippers performance
  221. Dyna 2006 stroker
  222. Tick tock
  223. 88" cam sensor
  224. TC crankshaft . . . ?
  225. Injector and Throttle Body Advice
  226. Fuel gage on the 2005
  227. 103 Head Work
  228. Opinions on Harley's long block program on TC 88
  229. Screamin Eagle heads 17015-03 , 17016-03
  230. oil pressure at idle
  231. 99 dyna camplate
  232. Oil pressure issue
  233. Oli Cooler line leak.
  234. Knocking noise 110
  235. Lean condition with fast throttle opening: CV40mm
  236. Rocker arm support plates
  237. Cams 101 question
  238. Fueling 574
  239. Oil filter bracket question
  240. Ticking Noise
  241. TC Rings and Pistons ID
  242. S&S 110 clearance
  243. TC88 stroker, which pistons?
  244. Thoughts on noise from my TC 103
  245. Engine Clatter when hot at speed
  246. When should cam shoes be replaced?
  247. Replacing Sprocket Shaft Seal, need help
  248. Umbrella valve upgrade - w/ so many options, how do you pick
  249. High idle problem
  250. Wimmer compression release
