- S&S Super E, Front Sparkplug White, Rear Sparkplug Tan
- 89 883 fueling issue
- Anyone have experience with Lectron Carb's??
- N65C Needle question
- 98’ 1200 - Engine bogging on acceleration after oil change
- 2002 883 Hugger Carb Question
- Throttle Cable question
- Hi flow AF with everything else stock
- Intake manifold removal question
- Harley carb rebuild kits
- Buell carbs
- Cv carb and intake manifold
- A/C options
- Carb to manifold to head bolt torque for S&S E
- Will S&S Super B Fit 1976 Shovelhead 74"?
- Gas purge on bike that has been sitting
- 2000 Sportster 1200 Cold start problems
- S&S Cycle's Premeation Compliant Fuel Inlet
- Kein jetting question
- Identifying Carburetor
- S&S Super E Shovelhead Conflict
- S&S Super E fouls plugs and won't idle w/o enrichener
- My throttle body and petcock leak gas need some advice on what could be the problem!!
- What carb do I have?
- My throttle body is leaking gas when I pull back on throttle
- My throttle body
- Keihin carb 38mm b79b
- Poor throttle response
- 2010 FXDB- Stalled out and will not start
- Fast Eddie's Float Bowl Drain Valve for S&S Carb
- Carb Problem, not your everyday problem!
- 2005 sportster 1200 won't run
- ‘05 1200 Sportster problem
- Air filters? Colors?
- Jis
- mm to carb conversion questions
- Puking gas at the back tire
- CV Carb -Soap & Water Clean??
- Help - Can't get the filter out of the tank
- Petcock experience - '01 FXDWG??
- Leaking gas
- Keihin Carb Parts
- TM42 Carb Surging Cables
- DYI S&S Msin Jet Tool.
- SU carb help requested please
- Cv40 needle jet help
- Carb jetting
- Gas Box Dog Dish AC?
- HSR 45 question...
- New or Rebuild?
- Hsr42 fitment issues
- Mikuni HSR 42 issues
- Mikuni question?
- Arlen Ness Super Sucker kit
- HSR42 Tune for 88TC fueling 525 cams
- Great Article on How a Carburetor Works
- EZjust mixture screw not so easy
- Mikuni TM40-6 Carburetor
- 98 Road King CV Carb questions
- CV Carb
- only start with starting fluid fresh rebuild on CV
- CV carb vacuum hose
- Tearing into my S&S Super E (Rebuild)
- Fake S&S carbs
- HD rebuilt carb
- S&S E fuel overflow.
- calling harley carb gurus
- Dating an S&S?
- Carb issue?
- Plug fouling - rich
- HSR 42 flat spot
- 27469-80a b83d carburetor
- Replacing Mikuni carb
- Surging at low speed?
- stock CV40 vs screamin eagle CV44
- JIS Screwdriver & bolt size
- Choke cable replacement on SS carb
- High Idle after warmup
- 1988 screaming Eagle sportster 883 carb
- What circuit causes hesitation/sputtering
- HSR 42 rich condition
- Carburetor clacking at high rpm
- Doherty power pacc
- Hi Flow Air Filter vs "Hypercharger"
- Hsr 45
- Mikuni clicking
- Super G to Super E swap
- CV carb air/fuel mixture screw
- Anyone know where I can get an old mikuni part?
- CV carb, 1998 Evo, rough at speed
- 98 Fatboy dumping fuel out carb overflow only while running.
- cv carb pouring out as, need help
- Changed ignition wont start
- 93 Fatboy hesitation and backfires
- AFR Front to Rear
- Adjusting idle
- Tuner's recommendation
- Enricher
- Air filter element?
- Fuel leak - drip from bottom of carb
- S&S Teardrop Air Filter Cover Bolt/Thread Size
- Hawgsbreath air cleaner
- Mikuni HSR42 Idle Problem
- Carburetor tuning screws
- Hesitation/Sputter/Backfire
- Filter cover(dog bowl)
- Do I need open air intake products?
- Fuel line size
- Help identify carb
- 04 Softail FXSTS no tension in idle cable
- Bought site un seen carburetor..
- Ultima R1
- Ultima R1
- Mikuni hsr42
- 1989 883 hugger sportster
- Should one use plummers tape on the enricher bolt?
- Mikuni experts..
- CV Jetting for 87 c.i. Evo?
- S&S Carb - Jetting starting point
- Did I screw up this carb?
- Night won't rev loss power at 80mph
- 2004 Heritage Softail - Runs like S***
- Is CV Performance Still in Business?
- Carb spit back
- Fuel leaking from carb
- Carb ID and bowl running out of gas
- S+S Carb rebuild ??
- Finely tuned machine
- 1985 FXRS Keihin Butterfly Carb and S&S Manifold Stuff ...
- Stock carburetor
- Leaky accel pump
- Does this Idle sound right ?
- 1999 Fatboy won't start on its own but will run.
- Carb ?
- S&S float adj
- Gas in oil? 2006 XL883
- 95 Roadking Stock CV with dynojet kit. Tuning help.
- CV Carb Q
- CV Carb Rebuild Kit for 2006 XL883
- CV Carb Leak
- Help with Petcock Diaphragm Assembly
- Carb tuning confusion
- Bad miss/petcock leaking
- Stalling at stop lights or slowing down
- S&S 124 and 48 Mikuni
- Pingel reserve issue
- Pilot jets?
- cv40 leak?
- 2005 sportster 883 carburetor slide
- 1995 Harley Softail Carb issues?
- Do I Need to re-jet?
- Fuel System Issues on an '05 Sporty
- Need advice on carbed fatboy
- '05 Fatboy--Putting Mikuni HSR42 carb on --Manifold ??
- Fuel dripping from accelerator pump boot
- Throttle cable adjustment
- Tuning a cv, exhaust question
- BIke (with carb) storage question.
- Mm to carb conversion
- 2004 1200r cam hs42 thunderheader main jet size??
- Backfiring on start
- Back to "old school" I go
- Cv40 idle up?
- 04 road king high idle when hot
- Where are the S&S Gurus at?
- '95 Road King Carb
- Evo carb tuning with Thundercone slip ons
- CV Carb issue 1990 FXST
- 27412-99c Carburetor
- 77 Sportster with Keihin Carb. Need Stock Jet Sizes & Numbers
- Decreased speed after carb tuning
- Harley sportster 883 revs fine, won't accelerate in gear.
- S&S super E Carbon build up/ smoke
- Odd Idle Mix Screw Adjustment
- Gas spitting out of carb at part throttle
- Jet size ???
- Mikuni upgrade
- Idle Enrichment valve
- evo intake manifold leak
- 01 Dina lowrider makuni carb
- Would like some help identifying this hd carb
- 1976 flh oem carb
- carb tuning 2004 eletrac glide
- Do I need to rejet?
- CV 40 to CV44--Manifold the same??
- Mild backfire/pop
- 1988 EVO Sportster with Screaming Eagle Butterfly Keihin
- Different thread types on main jets?
- Vacuum controlled fuel valve
- need help identifying part
- Just got my free s&s stealth a/c.....
- carb cough / bike dies on hard throttle
- Tillotson running rich
- CV Carb Tuning Issues
- New Carb for 1995 Road King
- 04 softail standard
- Fatboy 94
- 1994 FLSTC Air Filter
- A Little Carb Help Please
- Could lubing throttle cables (from the top) result in lube entering the carb?
- Keihin carb
- Super E running with idle mixture screw seated
- Fuel Tank
- S&S Carb overkill ?
- cv carb
- Carb Issue - Won't Idle
- S&S Thunderjet
- Carb tuning
- Accelerator Pump Push Rod
- CV Carb Accelerator Nozzle Diagram / Help
- Cv carb tuning last 5 percent
- CV modification
- Hose at the bottom of the carburetor
- CV Carb overflow drain tube question
- 48 mikuni S&s
- Need help identifying mikuni!
- Carb to EFI and vice versa.
- 2004 Sportster 883
- Tricky carb
- Mikuni jetting for V-111?
- 40 mm Kehein CV manual?
- Keihin carburetor top screws
- Accelerator Pump Help
- Jetting a S&S G
- S&S or Mikuni? And why?
- Which intake manifold--Mikuni or Harley??
- Mikuni HSR 42 setup VIDEO??
- Possible accelerator pump issue?
- HSR42 Only Idles With a Little Throttle
- Jet Needle
- 2000 fxd carb suggestions
- EFI to Carb conversion
- #45 jet blockage
- Need dowel that goes under throttle cable mount
- 96 springer fxsts
- Breather bolts and Velocity stack question
- Free***** S&S re-useable filter
- XLH883 Only Runs On Choke... (it’s not the pilot jet)
- What am I missing?
- Pop with fuel squirt
- I want to piss people off
- Idle “races” when hot
- Carb Upgrade
- Road Gremlin, 01 Tc88b popping issue
- Carb Question - Symptoms
- Is this a "cough"
- Carb Question
- Type of throttle/idle cables for S&S super 'G'
