PDA
View Full Version : Carburetor Related
Pages : 1 2 [3] 4 5 6 7
  1. Type of throttle/idle cables for S&S super 'G'
  2. CV carb tweeking
  3. Location of idle and throttle cables on S&S super G
  4. Carbed Sportster motor in efi frame?
  5. CV carb AIR jets
  6. California 97 CV carb with two (vac) barbs
  7. Change carb brand or no?
  8. Pop pop and ahh chooo
  9. Got a Sick Piggy. Only Running on Choke and Restarts on Reserve?
  10. The extra carberator part
  11. stop, just stop!!! monkey wrench
  12. Mikuni HS 40 A/P Boot Replacement
  13. starting issue, fuel related?
  14. Fuel Issue
  15. Where to buy cv parts
  16. Running lean
  17. Spits and sputters/hot
  18. Spark Knock?
  19. CV carb tuning with a wideband
  20. Carb issues
  21. A/F It either spit or backfires. No inbetween
  22. Jetting, fuel air mix?
  23. Simple Carb question with simple answer..
  24. Keep stock Airbox or Upgrade?
  25. Petcock Leaking + Vacuum Line missing
  26. Line from carburetor 05 Sportster 1200C
  27. 88 Heritage Softail Carburetor
  28. 1979 xl 1000 idles great dies when throttled
  29. S&S carb mouting woes
  30. CV Carb Needle Jet Holder Different
  31. S&S Carb Help
  32. Super E, running out of possibilities
  33. CV carb leak, i feel like I've tried everything!
  34. Why so big?
  35. Help diagnose friend's bike - engine won't turn over
  36. TC88 high idle when warm
  37. VOES on mikuni hsr 42
  38. Fuel Problem
  39. TC88, maybe lean, weird jet sizes
  40. super E. idle variance
  41. My 2001 harley sportster 1200 stalled several times
  42. Popping and Backfire-- How do I fix this?
  43. carburetor help
  44. Carb setup guidance needed.....
  45. Rebuilding CV carb, have questions...
  46. Best jets for S&S V111 with yost power tube
  47. Coughing through carb when key turned to light position
  48. Harley Not loping after 600rpm high idle no exhaust sound
  49. Random sputter
  50. intake manifold supposed to move?
  51. 99 TC carb rebuild
  52. Stalling issues
  53. 01 Fatboy with mikuni 42
  54. main jet?
  55. 97 Softail Custom Leaking Fuel from Carb
  56. 2004 Road King Custom carberator
  57. Added New Mikuni Carb now wont start
  58. Gas Mileage Evo 80
  59. Stock Cams to S&S 509 Cams
  60. S&s super b carb
  61. A gasket for the fuel tap nut?
  62. High flow petcock rebuild
  63. My FXR ain't pulling like it used to?
  64. S&S super e idle not right
  65. aggerevating fuel leak from over flow
  66. Fluid at bottom of air cleaner cover
  67. Symptoms it time to "service carb'
  68. S&S super E
  69. woods carburetors??
  70. Air filter wet with gas.
  71. No Fuel-Suspected Vacuum Petcock, then.......
  72. Hesitates, Backfires, and Dies
  73. Need help 04 883 stalls low idle
  74. screamin eagle '88 Harley Davidson Heritage softail
  75. Replacing Petcock - How to Plug Vac
  76. Just another Carb issue
  77. Mikuni VM44 fine tune
  78. opions on thunder jet for s&s super e carb
  79. SIS backing plate question.
  80. Weird CV issue, gas around accel nozzle
  81. Rain Sock
  82. Been browsing this forum, feeling like a hotrod
  83. Weird CV carb issue
  84. Vacuum bypass the petcock
  85. Throddle housing crank on carb spring
  86. Evo cv carb tune
  87. Leaking mikuni carb
  88. Carb drain
  89. 2002 Fxdwg3 s&s carb with screaming agile heavy breather?
  90. Stock Air Filter Clean
  91. Straight (Non-tapered) Stage 1 Filter?
  92. Does this filter need oil?
  93. Enricher problem
  94. S&S E carb question
  95. Carburetor ejected
  96. Help! Main Jet missing! Is this even possible?
  97. Should I rejet or leave it alone?
  98. 2014 iron modified air intake / filter system
  99. Carb identification
  100. Varnished Carburetor Blues
  101. Is it time for a carb rebuild??
  102. S&S E or Mikuni 45
  103. S&S Super G question
  104. Velocity stack rejetting
  105. Velocity stack rejetting
  106. Lucas7118
  107. S&S Super B with Superbowl (accelerator pump) rebuild kit
  108. 95 1200 Sportster
  109. Need help with the breather for SS super e
  110. 97 Dyna running bad
  111. sportster carb help
  112. Carburetor issues 42mm Mikuni
  113. Fuel tank gunk/inline fuel filter woes
  114. 2002 dyna with ss super e help
  115. 03 FXDL Always too rich
  116. Leaking oil, but what could be the reason
  117. Super g starting point
  118. Monster Sucker question
  119. Super G on modified 80" Shovelhead
  120. Ss super e shorty on 02 dyna with screaming eagle 110ci
  121. Sportster puttering and stalling
  122. 91 harley sporster cv accelerator pump nozzle replacement part
  123. CV51 to HSR45 conversion conundrum
  124. Best loc tight for crank case?
  125. hot starting problem,
  126. What gives me more fuel
  127. CV Carb Jetting
  128. My bike was stolen i need some help
  129. CV Carb jetting question
  130. Any one with a TC BROS cleaner?
  131. For those who have done the stage one air cleaner? Question..
  132. Runs rich, floods out under load
  133. CV40 carb or SS super G
  134. Proper jetting PhxTo Utah
  135. Carb idenification
  136. Getting Close to solving my carb
  137. Stock adjust shocks
  138. Do I need to worry, fuel puddle in aircleaner
  139. Fuel Problems with 2001 Fxdwg
  140. Need Help, looking a Float
  141. S&S Shorty Carb rejetting
  142. Help with idle speed adjustment
  143. Help with idle speed adjustment
  144. New to carbs
  145. Carb issues?
  146. 01 fxdl carburetor gas leak?
  147. Still having issue i copied my original here
  148. enrichener cable sticking
  149. Disable Mikuni 42 Acc pump
  150. Mikuni 42 needle washer size...HELP!!!
  151. Intake popping
  152. Water drip from Air Cleaner 2001 Softail
  153. ??? Mixture problem??? or???
  154. Air vs Fuel
  155. keihin carb float
  156. Dellorto Carb Will Not Idle
  157. Mikuni Hsr 42 problems!!! Please Help
  158. Hsr42 or build up stock CV carburetor?
  159. Thunder Mountain - SE 103 Carb
  160. Float Height for 1988 Sportster 883??
  161. CV Jetting headaches
  162. HSR 42 question
  163. Haven’t ever touched a carb..
  164. Did a 180° turn and back
  165. Dual carb evo.
  166. VOES 1986 Electra Glide
  167. 95 kit and mikuni 42 tuning
  168. Having to blip throttle every start
  169. Cough on upper throttle range
  170. Mikuni to Cv Breather or S$S breather
  171. 92 sportie with scream'n eagle pipes (stage 1)
  172. SS Super E Carb
  173. Where to purchase carb jets?
  174. Lightly seating
  175. S&S 111 super E won't start
  176. 1996 Ultra Electra S&S Carb
  177. 2004 883 Sportser Hesitates/Dies with Throttle
  178. Super E turning
  179. 97 EVO Mikuni HSR 42 Mileage
  180. Too many variables
  181. Can carb be Re-jetted from 42mm to 38?
  182. Another dynojet reversal.
  183. Carb jets//
  184. Black smoke upon shutting EVO off?
  185. Carb kit 75 sportster
  186. Rebuilding carb on 99 Dyna Wide Glide
  187. Impossible Intake Seal
  188. Air filter
  189. Carb jet needle wear.
  190. S&S Super E jets
  191. Arlen Ness Big Sucker maintenance
  192. MM to carb
  193. Carb mileage
  194. looking for a compression style fitting
  195. Too Rich
  196. Carb Rebuild Advice
  197. fxr 113 mikuni 45 question
  198. Rebuilt Mikuni 42 rich?
  199. No power in 5th gear
  200. 97 sportster 883
  201. 1984 fxrs
  202. Carb coughing..etc
  203. Fuel filter
  204. My custom stock stage 1 AC
  205. No Fuel Flow
  206. Nasty backfire..
  207. Question on Super E
  208. Pop at carb
  209. What air box is this?
  210. 2002 Low Rider Carb issue maybe
  211. Needle Jet is upside down, but won't go in the correct way.
  212. Intake Seals - Tools?
  213. SE44mm Jetting Help for 107" Softail
  214. Carb - Needle - What Species is this?
  215. S&S carburetor shovelhead
  216. gas leak
  217. Bogging
  218. Mikuni HSR 42 Tuning.
  219. Installing a mikuni carb on a s&s 111
  220. Differences in Carburetors?
  221. CV Carburetor Help
  222. Lean running 883/ hammer 1250 conversion?
  223. S&S and my bone stock 85 flhtc
  224. Edelbrock
  225. New cables but missing cruse control
  226. Bottom of carb not going back on
  227. getting confused
  228. New bike to me. Just size
  229. CV Carb trouble overnight.
  230. Removing Carb - Throttle Cable Issue
  231. 2000 wide glide
  232. 2002 Heritage Carburetor Conversion
  233. How to determine existing pilot jet size ?
  234. Rebuild or adjust?
  235. Mikuni Carb ID
  236. 96 EVO carb questions, more than one.
  237. Carb pouring gas
  238. Why Carburetors Will Be Around Forever - Joe Minton
  239. Carbs problem.
  240. Fuel pouring from air filter
  241. Mikuni SE EV27 jetting
  242. 03 FXDL Jetting question
  243. Backfire problems!!
  244. Trying to tune up a '95 WG
  245. Super E rebuild
  246. New CV51 Carb
  247. HSR 45 air cleaner cover
  248. Can't afford dyno
  249. 89" Stroker Jetting
  250. FI carb Swap
