View Full Version : Carburetor Related
- Don't think it is the float?!
- new guy-backfiring & loss of power
- Buell s1 with screaming eagle carb
- Jetting specs
- accelerator pump
- Perfect tool for carb adjustment.
- No fuel to the carb
- bendix carb tuning help
- Backfire from carb
- cv conversion on 85 evo
- Rare? S&S Super B with Accelerator Pump
- Carb rebuild fail - help!
- CV part identification help!
- hello have a s&s carb want to change to a hyper air filter kurakan
- Mikuni HSR 42 Install Help on 2000 FLHTC
- Help I can not stop!
- CV Float Pin Size?
- S&S Super E excessive fuel use
- Retapping petcock threads
- Sportster Dies with Throttle
- Help with a shovelhead fuel delivery problem.
- 90 FXR Carb Will Not Stop Leaking
- Hard starting when warm
- Float bowl overflow fitting???
- 04 xl1200r carb question
- 06 Roadking CV carb
- Excess Fuel coming out from Main Jet Holder
- 1994 Ultra with cruise control - carb change?
- 2003 FCC sputters when driven
- Efi to carb big bore
- Help: Cleaned carb now won't start
- Did I ruin my CV carb with carb cleaner?
- Installing EFI on an XLCH Ironhead?
- Need help finding float valve seat
- What is the best rpm for the bike to be set at?
- Carburetor saga
- gas line
- Tuning after new cams
- 1992 Fatboy carburator
- Needle Shims
- Bike stalls at stop lights
- Choke Cable Question
- Engine oil in my air filter
- TC88 Carb differences
- Running Rich
- Carb leaking problem
- What would you start with for this setup? (Jet size)
- CV - Just a little popping
- 83 iron head carb black smoke
- Acceleration stutter CV twin cam
- Hesitation on my 03 heritage
- Air line?
- S&S Super "G"
- Am I on the right track
- EVO Carb Jet Recommendation
- Reserve pet cock and vacuum line question
- 1990 HD Sportster 1200 FUEL PROBLEMS?
- OMG It's not the gas but the air
- Zenith carb
- S&S Super E Jets for TC95
- warm start combo
- mikuni hsr 42mm jetting questions
- My bike is a flame thrower!
- 2004 Sportster customer Carb Probs
- Collar location
- 1993 EVO hesitation or stumble cold start
- Erratic Idle RPM's and stalling when up to temp
- Help! I rejetted my carb and my bike stutters at take off
- Swapping the carb
- Carb id
- Running dangerously Lean on 1992 FXDC?
- 120-130 km/h sputter
- Keihnin butterfly cold-blooded
- 86 Sportster carb swap
- Ghetto gasoline- don't do it!
- Popping and misfiring. Help needed.
- Carb Cock Block
- 97 Road King Vacuum Petcock
- Mikuni HSR42 install?
- 05 XL1200 wont idle, been sitting for 2 years
- Help!! Mikuni HSR 42 accelerator pump is stuck!
- Bendix Carburator
- carb pops
- 1991 and earlier CV vs 1992 and up (big twin) - float
- Cv 40 problems
- Possible flooded carb? Flooded carb symptoms?
- CV Carb Question
- New member with Super E problems
- Dual carb setup for 89 sportster 1200
- cv 99D, 190/45 with open pipes was backfiring big-time, so I decided to rebuild the carb.
- Motor bogging under open throttle
- Mikuni Hard Start When Hot
- Oil in the Air Cleaner Housing
- Keihin Leak
- What happens when the diaphram in the petcock goes bad?
- Full or partial Super E rebuild?
- Air intake kits
- Carburetor compatability
- hiccup through carb
- Which epoxy should I use to glue a hose barb fitting back in to a Petcock ?
- Fuel overflowing out
- First Time CV Carb Jetting
- Mikuni Jetting on a (Mild?) 103 ci Build
- Mikuni choke cable is missing the spring clip.
- TC88 to 95" w/ Screamin Eagle 203 Cams: Need to rejet my carb
- 1967 ElectraGlide throttle assembly
- Stumbling in take off... Please help
- 2000 Fatboy wont run correctly- Fuel/ Air issue- Help
- Are all twin cam 88 carbs the same?
- Need Weber Carburetor part number
- 2004 HD xl1200r carb adustment
- Super E PITA
- CV help
- Where to find vacuum slide for CV44 Carb?
- Starting problems '89 1340
- Roadking 88 cubic inches 1998 Carburator
- Idles too high, engine overheats
- Drilled the wrong plug?
- Jetting for a mild 95" CV40
- Mikuni HSR42 TC95" Jetting
- 06 CV carb fuel issue
- mikuni hsr 42 Q's
- Re-jet (CA model)
- Idle Problem
- Woods Performance Carbs-Worth the $?
- aftermarket aircleaner
- Electra 2009 fit carburetor
- Replace Carb
- "spitting" carb
- Best air filter for S&S super Carb?
- overflow issue.... still...
- CV carb part - 2003 XLH883
- Replaced stock CV carb 99XL1200Sport
- SE Slipons to D&D Fatcat
- Carburetor overflow leak
- What to do to the carb after I install shortshots and new a/c?
- Carb rebuilt...now for troubleshooting...
- Boring an S&S E Carb.......
- Shovelheads plugs issue
- 2000 Wide glide carb popping
- Aftermarket Air Cleaner Question
- HELP 2004 heritage dies on throttle up
- Winter Storage
- L-joint
- 2004 Sportster 883 - Rebuilt carb and now she won't run
- Keihin CV carburetor float pin replacement source
- DynoJet, CVP...? Lordy...
- squeaking?
- CV carburetor vacuum line
- Replacing Kuryakyn Hypercharger......
- CV Sucking Fuel From Accel. Nozzle
- Carbureted Virgin
- S&s Super E Fuel Dumping
- jetting issue?
- MIKUNI HSR45 getting it dialed in
- S&S Super E Jetting Help
- cv carb question. need advice
- replacing fuel fitting question
- bike stubles when warm Help
- 2004 Heritage Carb Setup - No Clue Why Still Running Lean
- 1970s shovelhead issue might be carb related.
- Bent CVP EZ-Just screw needle
- carb swap
- S&s super e
- Re-jet for new Vance & Hines Pipes
- thunderheader jetting questions
- Prolem with se 95 with hsr mikuni42
- Need more for my evo
- !%*!#$ torx
- S&S Super E
- Huge pilot jet running rich. Duh.
- Carb Drama on a TC-95
- Problem with Super E and turbo air cleaner
- Bike won't start
- carb size
- 89 sporty throttle cable question
- 1988 883 Sportster carb woes...help!
- Rejet due too altitude
- need help with super g carb
- sluggish out of 1st gear
- CV Carb hose...
- Mikuni carburator ajustement
- Rebuilt, rejetted, '06 FLHR. Uneven idle when hot?
- please help asap. selling one of my bikes today
- 95 sportster chokes wide open
- Carburetor help!
- Help needed with old sportster - Mikuni HS40 carb
- nasty carb overflow, still!
- S&S Super E (Lean?) 1991 FLHTC
- I come to you, carburetor gods......
- Cv carb swap on a 103 Cu/in
- cv rebuild
- Help! Accelerator pump & Nozzle--no squirt!
- carb adjustment for exhaust change
- different carbs
- trying to figure out what mileage should be
- screaming eagle keihin
- 89' sporty accelerates itself
- Sportster needle in Dyna CV carb?
- Stock cv carb rough idle 92 evolution
- 1996 evo heritage jetting help details inside
- Any Bendix Zenith Experts Here?
- '99 883 XL CV 40 Carb Upgrade CChrome Kit 040561 Settings?
- Carb rejetting help in DFW area
- 2003 xlh 883 CV rebuild instructions
- 91 evo intake manifold seal leaking problem!
- carb issues
- S&S shorty E questions
- 2006 XL1200R Sportster slow jet
- rejeting a S&S carb on a evo
- Choke wont stay open...
- '97 Evo Needs Enrichment pulled to Idle
- Thunderjet Kit - does it work?
- Larger main jet?
- Exhaust Back Fire
- Carb Cutting out After Warming up on 99 Twin Cam
- FLHT '06 jetting
- 93 sportster 883 won't idle
- Change FI petcock to 1 for carb
- Poor running on larger throttle openings
- Mikuni hsr 42 mm install/help
- 98 Low Rider idle problem
- '97 FWDWG Enrichener Cable Replacement
- 96 RK, Mikuni 42 Carb, Won't fire after flooding???
- Mikuni HSR42 "Old Style"
- Help me remove socialism from my FLHT
- 88 fxstc
- Carb Rebuild?
- correct way to install petcock and fuel filter on a 93 sporty
- 80" Evo with open pipes, jet question.
- 2000 Sportster 1200C Carburetor 27480-97A
- jetting question?
- Jetting and A/C question
- 2002 FLSTF Air Cleaner IDing help
- 107" 113" twin cam
- jetting
- Carb Problems!
- Sportster round air cleaner
- Stock Carb
- SU Carb
- READ this for CV carbs and stock carb fixes and tuning on your evolution motors
- Screamin Eagle Carb...Anyone familiar?
- Carb Conversion?
- Woods King 40.5mm Carb
- Trouble adjusting throttle cables
- EZ Just Idle mixture screw
- '02 FXD & 'Enricher' ??
- Carburetor vs Fuel Injection in Winter
- Carb help needed: starts, but dies when open throttle
- Air sucking in when I roll on the throttle?
