PDA
View Full Version : Carburetor Related
Pages : 1 2 3 4 [5] 6 7
  1. Air sucking in when I roll on the throttle?
  2. CV or Mikuni
  3. s&s or Mikuni
  4. s&s or Mikuni
  5. Air cleaner
  6. Starting point on 98in build
  7. Stock jet sizes?
  8. front cylinder rich and backfires
  9. Smell gas with heavy acceleration - Carb
  10. Spike A/C jetting issues
  11. Mikuni PHH
  12. Leaking Carb?
  13. Help with petcock truobles please
  14. 2005 883 carb questions.
  15. Mikuni HSR42 Rebuild
  16. '90 Sportster 1200 Carb Idle Problems
  17. 2001 fxdwg 88 TC carb help
  18. different threads
  19. 65FLH which carburetor?
  20. 1995 harley sporty 883
  21. Carb issues
  22. Carb Removal
  23. s&s G series carb choke (enrichment) question
  24. 75 FLH carb
  25. 94 fatboy running insanely rich
  26. help with rejetting and tuning
  27. loss of power
  28. hard to start
  29. gas smell from air cleaner
  30. carb conversion wiring harness question
  31. CV carb help
  32. Stock CV-S&S-Mikuni
  33. S&S round stealth air cleaner set up
  34. Please Help! - Issues with S&S Supper E
  35. S&S super E question
  36. 98 wide glide carb problems
  37. 2005 Lowrider with serious carb issues
  38. Mikuni Carb on a Wide Glide
  39. Old school meets new school
  40. Why is my Pilot so High?
  41. 1996 FXD problem
  42. Rough running at low rpms and decel popping in carb
  43. S&S Tear drop upgrade
  44. 1200 evo air filter wet with gas?
  45. Starting issue
  46. overflow
  47. what did I miss/mess up
  48. Won't idle and choke won't stay on
  49. Super E vs. Supertrapp True Duals
  50. SPORTSTER 1200 - MIKUNI HS40 - no idling
  51. Super E carb vs. crank case breather line/filter
  52. dynojet main jet replacement
  53. cold weather blues
  54. 01 FXDXT Carb =
  55. 1340 evo carb trouble
  56. Carb slide vent hole repair?
  57. CV carb lost idle circuit
  58. 2004 sportster carburetor question and help
  59. Looking for info on second float bowl hose
  60. What's the bare minimum?
  61. 2005 Sportster Carb Issues?
  62. Choke in the Summer?
  63. bowl keeps overflowing
  64. cv excellerator pump leak
  65. 1/4-1/2 throttle sputtering and backfiring on decelerate.
  66. Check Needle under Accel Pump Nozzle
  67. Super B Rebuild
  68. Front plug fouling
  69. S&S Carb vs Stock CV ??
  70. cv carb pulling gas from main jet at idle
  71. iddle only
  72. Intake manifold leak
  73. Need step by step
  74. New member w/ a "new" '78 FLH
  75. Lean backfire advice?
  76. Engine "cough"/backfire
  77. '77 Sportster
  78. Fuel spray
  79. Carb tuning help
  80. Cold start issues '74 Sportster XLCH
  81. How to reduce air leak around manifold?
  82. Any shops in Dallas area that will work on carbs?
  83. Mixture Screw Broken!
  84. Choke lever kit.
  85. Thunderjet tunning? Need help
  86. 05 sporty Revs fine but sputters on accelleration
  87. Leaking float retaining pin - S&S super B carb
  88. Pipe Swap Carb Jetting
  89. Mystery O-Ring
  90. Please help me read my plugs!
  91. Jets
  92. no response on idle jet
  93. Mikuni 38 mm round slide carb
  94. S&s super B on Shovelhead
  95. Carurator
  96. How to remove S&S carb?
  97. 2002 Sportster 1200 acting up
  98. Looking for a #47 pilot jet for my 2006 sporster
  99. Choke question...
  100. 1991 UC fuel inlet
  101. mikuni help
  102. makuni
  103. 2003 fxst caughing and pops
  104. Carb overflow off of float
  105. Jetting
  106. Broken Overflow tube.
  107. 2001 883 cold start issue
  108. Sportster spitting gas out of carb and bike is losing power
  109. CV Cleaning - 'extra' part
  110. S&S Super G problem I created
  111. 2006 Carb 1200 Sportster Fuel Efficiency
  112. 2003 xl883c serious problems
  113. Help ! Rejet carb on sportster now ?
  114. 2006 1200 custom carb issue
  115. Harley CV Carb Vacuum Hose Question
  116. Carb problems 2005 XLC
  117. 2000 Fatboy Enrichment cable
  118. Did I over jet?
  119. Is this kit what I would need
  120. cutting out
  121. Custom bike dies when down to 1/4 tank
  122. CV acc.pump pouring/not filling bowl
  123. 2001 Sportster 43mm carb question
  124. 2000 Sporty with SE 2 slip ons
  125. S&S Air Cleaner on 2000 Fatboy
  126. Low speed needle exchange
  127. 98 FXDWG Jet settings
  128. 91 Sportster Fuel Line Routing/Protection Question
  129. Stock intake vs screamin eagle intake
  130. S&S Super E ejector jet!?
  131. 2003 fxst rejet questions
  132. Fuel Crossover Line 1985 FXRS-SP
  133. Technical Jet question
  134. Carb adjustment
  135. Stock jetting on an 2003 FXST?
  136. Looking For A Good Starting Point
  137. Pingel petcock output slight smaller than S&S carb inlet...problem?
  138. Leak from gasoline tank
  139. 2000 Sportster
  140. Zenith Bendix Accelerator Pump
  141. Twintek first start, modded stroker, settings?
  142. Help ! fuel leak from Carburetor.
  143. s+s carburetor air cleaner
  144. This Lil Piggie went to market
  145. Fuel Tank Vent Line
  146. Running the bowl empty
  147. vance and hines f.p.3
  148. Gas problems on 03 heritage softtail
  149. CV carb part number
  150. Need help on part # for needle seat - Honda shadow
  151. no gas
  152. 88 to 98 jetting
  153. 2001 Electra Glide Classic
  154. need help diagnosing high idle issue
  155. Mm efi
  156. 1200 kit what jet do i need?
  157. 82 XLH1000, PLEASE HELP!!!! in need of parts & have some parts if you your in need.
  158. Carb choice
  159. lose carburetor
  160. SS Super E adjustment
  161. Fatbob fuels tanks too small
  162. Using choke and warming up before riding
  163. tired of the carb
  164. 99 Sportster not starting, new battery...
  165. 05 heritage not starting/Rough running
  166. Fuel Injected Model Sensor Signals
  167. carb help please
  168. 1999 roadking fuel tank removal
  169. Gas Tank Internals PM
  170. 98 Softail
  171. Crappy gas mileage or normal?
  172. do i need to rejet my cv carb?
  173. Fuel leak
  174. aluminum foil in gas tank
  175. S&S Super E Strong gas odor
  176. My dynasty super glide is missing
  177. Which carb best for s&s evo 6ci
  178. Who here rebuilds Pingel powerflo petcocks?
  179. Fuel leak '94 Softail
  180. Old 95 Ultra stored for 8 yrs
  181. Cracking tank
  182. QD fuel leaking
  183. Petcock filter upgrade, inline fuel filter and source of fuel debris
  184. Help with install of SE Ventilator
  185. Cutting out and Decel Pop
  186. Trying to help get my buddies bike running, Possible fuel and carb problems
  187. 1999 Ultra Classic
  188. Eating Air Filters
  189. Rear Cylinder Popping - 2001 Roadking
  190. CV carb assistants
  191. 86 Harley FLT
  192. S&S Super E Shorty Rebuild
  193. no fuel from bowl to cylinders
  194. S&S super e
  195. su carb
  196. sticky threads on rejetting
  197. Super e carb
  198. Need Help with 1200 Sportster (fuel/throttle)
  199. Injectors not cycling?
  200. 1991 Sportster Carb Leaking - video included - HELP
  201. Help!!
  202. Rejet Suggestions for '86 Keihin Butterfly Carb.
  203. Quickly and badly fouled plugs- HELP!
  204. Super E o-ring and check ball question.
  205. Work In The Progress! Advice?
  206. Cobra Fi2000
  207. super E tuning
  208. 96 fxstc oem carb 27492-96
  209. Anyone using Boyesen twinshot
  210. Choke slips 1990 Ultra
  211. Carb / jet issues
  212. CV carb question
  213. changing fuel gauge to led fuel gauge
  214. makuni hrs 45
  215. twin dual throat weber dcoe
  216. mikuni help
  217. jetting help?
  218. Need help with backfire and wheezing issue.
  219. HELP!! throttle/idle ring-clip install
  220. loss of power at higher rpm
  221. Having Flooding problems
  222. Removing fuel tank 03 FLSTFI
  223. Need help with HD sportster fuel gauge kit
  224. cuts out
  225. Mikuni VM carb help
  226. carb popping
  227. Expose air filter
  228. new gas tank
  229. Fuel question
  230. Help Carb issue
  231. Custom Fuel Tank
  232. S&S Super E on 80"EVO
  233. All-American Rejet
  234. velocity carb on a 87 flhtc
  235. Exhaust Change Question
  236. keihin question
  237. Forward throttle rotation
  238. Fuel supply valve on 98/1200 Sportster
  239. Fuel Pump Quick Disconnect leaking - 2008 FXDF (pics)
  240. 88 to 95 cubes, do I need to re jet my carb?
  241. '06 died after short shots installed....troubleshoot
  242. Help!! Carb prob. Mid throttle sputter and dies
  243. stage 1 question
  244. fuel leak
  245. Increase Performance on 1200 Sportster
  246. spike air cleaner install suggestions
  247. idling
  248. 2010 dyna idle
  249. travel lenght ?
  250. What color is the tank lining in a Road King gas tank?
