Power Vision Information Thread
"In closed-loop mode, the O2 sensors dont adjust the fuel maps. Instead, they completely take control away from them, causing the temperature and pressure sensors to have no effect either"
How does it eliminate the map sensor when on the new bikes the lambda tables are map/rpm based? If it doesn't adjust the fuel maps how do the AFV's work? The IAT sensor also tells the ecm the "quality" of the air.
"When I twisted the throttle one-quarter open, notice that the rear cylinder (red) went a little lean, running open-loop on its fuel table during the acceleration."
Both ends of that afr graph the bike is in open loop. That is why the ecm relies on accurate ve tables to deliver the correct amount of fuel, nothing to do with the closed loop portion of the map.
"The problem is, it will still be that lean at three-quarter throttle while trying to make 60-plus hp."
I doubt that at 3/4 throttle you at at a low enough kpa to be in closed loop. There is no reason not to run closed loop in the light load/cruise area if the parts of the system are working as they should. Poor o2 sensor installation in exhaust pipes are a big issue with getting the system to work. Typical computer, garbage in, garbage out. Closed loop will allow your bike to adjust for different grades of fuel.
They've asked me to get ideas here on how to improve the display feature. I think a separate selection screen similar to the Trip Center would be the way to go. Have each gauge with a box that can be checked or unchecked, and only those checked will be displayed when scrolled.
Now, let's hear more suggestions! I'm getting burned-out on scrolling.
Check box would be an enhancement.
I'd appreciate a display with as many gauges as possible : RPM, fuel, speed, weather forecast... :-)
JJ
I have yet to find anyone to first do a "pro" tune and then later do a hand tweaked street tune and then go back the the "pro" dyno tune after the experiment.
All the big changes normally are in the drivability/midrange part of the tune. The Sportys have the biggest issues as they can not be ridden in closed loop without huge downsides.
Beast
Beast
I've had headwork, larger throttlebody, larger injectors, roller rockers and Woods 408-6 cam installed on my 110. My dyno tune is excellent but the entire map is out of closed loop therefore it's not possible to tune with the PV, at least in open loop with the stock NB sensors.
Unfortunately I would need to change out my exhaust bungs to accomodate the larger WB O2 sensors in order to tune my performance map.
I did however tune the bike to develop an "economy map" where everything below 3000rpms is in closed loop. I used the PV to tune below 3000 to optimize the engine for fuel economy and above 3000 rpms I use the tables that were developed on the dyno.
The difference in fuel economy between the 2 maps is significant. The economy map generally gets around 43-45 mpg while the performance map gets around 35mpg. The downside is that while the performance of the economy map is smooth it also does not have the giddy-up of the performance map.
If I had WB sensors that would allow me to further improve on the dyno-tuned map, I would definitely try tuning the performance map to see if any gains could be found.
At what MAP reading do you jump out of closed loop? I tend to tune where the bike runs closed loop at what ever MAP it holds at cruise on the highway. Any more than that on the MAP and I jump to 14 AFR and slide to richer as I climb to about 13 AFR.
Beast
The bike runs extremely smooth with both maps. Absolutely no stumbles or backfires and very crisp throttle response. The difference between the 2 maps really is the trade off of fuel economy for power below 3000 rpms. There's also a slight increase in engine temp with the economy map, about 10-15 degrees hotter in economy.
The PV allows me to change the map whenever needed and also provides real-time monitor of engine temp, fuel economy and other measures of interest.
