Power Vision Information Thread
Old Jun 7, 2012 | 10:14 AM
  #2541
iclick's Avatar
iclick
Originally Posted by Marcusp
Iclick what does a knock event look like?
If you're logging Spark Knock, Front and Spark Knock, Rear you will normally see zeroes. If a knock event occurs there will be a value >0 displayed, in my case with the false knock I usually get "2" for a few seconds, then it tapers to "1", "0.5", and back down to zero. This represents the amount of retard evoked by the ECM to get rid of the knock. How much you get depends partly how you have Max Knock Retard set. The default for me was "8", meaning it won't retard more than 8°. I set mine down to "4" but it rarely applies that much.
A false knock event is one which can't be dialed out by retarding the timing. For example, let's say you have 20° of advance at a given location and get 2° of retard from the knock sensor, prompting you to reduce your advance to 18°. You then get another knock event from the Spark Knock parameter and you reduce it down to 16°, but following this procedure never stops the knock event. What's more I never actually hear any knock events, and the false-knock for me has always been at a point where I normally wouldn't expect to see it.
Old Jun 8, 2012 | 11:21 PM
  #2542
Teardrop's Avatar
Teardrop
I just updated my PV to the newest firmware update. Does anyone know what changed?
Old Jun 9, 2012 | 08:18 AM
  #2543
HotIceHD's Avatar
HotIceHD
Sorry to ask what is likely covered in the 255 pages, but the ones I went through did not mention it.
Does PV mate with your bike's ECU? IOW, can you use it on different bikes you own?
Old Jun 9, 2012 | 08:59 AM
  #2544
883_dave's Avatar
883_dave
The PV does "Marry" to your ECM, but you can purchase additional licenses so that you can use the same PV on different bikes.
Old Jun 10, 2012 | 10:26 AM
  #2545
iclick's Avatar
iclick
Sorry to ask what is likely covered in the 255 pages, but the ones I went through did not mention it. Does PV mate with your bike's ECU? IOW, can you use it on different bikes you own?
It's married to one bike as soon as you flash a tune to it. Once that is done you'll have to buy additional licence(s) to have it flash other ECM's. You can, however, run datalogs and monitor gauges with any bike.
Old Jun 13, 2012 | 06:08 PM
  #2546
Delta's Avatar
Delta
Default How much to retard timing
Tomorrow I am going to do the Ride To The Sky, Mt Washington Auto Road. It is a Laconia Bike Week thing to do. I have done this 2 times before, on a 2004 and 2008 Ultra. Both pinged too much for my liking. The 04 was a 103, 258 SE cams, true duals. The 08 was a 103, 255 cams SE II slipons. Hot days, hot motors and slow traffic going up and up. I am using a Fuel Moto supplied map with the VEs and Lambda values adjusted by datalogging, spark maps remain unchanged. I am thinking of retarding my timing by 2 degrees and maybe making it a bit richer as well. Possibly using a fuel additive. What does the PV brain trust recommend?
Old Jun 13, 2012 | 08:10 PM
  #2547
papifun's Avatar
papifun
i have a question but not sure where to ask it.. I have the PV.. i was in Lake George NY for the Americade and plan to go to Laconia for first time for weekend.. I have stopped by the DYNO's guys that was at the Americade and mentioned i have a PV... he laughed and says he cannot dyno my bike with the PV.. its not a live tuner... i have been using the PV since last year.. i like it.. .used log tuner, but was curious if my bike was tunned right and wanted to see it on a Dyno... i still havent met anyone here in Quebec area that has worked with the PV... are they afraid of it ? .... i think its a superior product...
Old Jun 13, 2012 | 08:21 PM
  #2548
iclick's Avatar
iclick
To you guys who are using the beta firmware (1094), I'd like to ask you to do a little experiment. Flash your current tune to the ECM, then Load Copy of that tune and compare the VE values. To do that, go to Program Vehicle > Custom Tunes > Load Copy, then save it to a slot in the PV. In WinPV "Get Tune" and compare the two tunes. The VE values should be the same except for minor rounding changes. (I.e. 92.3 in the original tune may round to 92.5 in the copy).
Old Jun 13, 2012 | 08:41 PM
  #2549
Delta's Avatar
Delta
I think what the difference is, with the Power Commander series, the tuner could play with the fuel and spark and never have to shut the bike off. He could make the changes that the sniffers were calling for and by the overall feel of things due to his experience. Of course, these adjustments couldn't be flashed to the ECM. The change in values were added to the hardware connected to the ECM, intercepts the signal coming from the ECM and makes adjustments before sending to the engine. That's the reason for the O2 sensors being disconnected. The dyno tuner was able to see the results of the changes in an instant; in real time.
With the PV type tuners, that flash the new tune to the ECM, the dyno tuner now has to follow the downloading procedures of the unit being used. Typically all require the bike to be shut off, load the tune, wait 10 seconds, restart the bike and do it all over again. He would have to datalog more than once to get the DELTAs to an acceptable level. Quite a time consuming process. All this takes time to do correctly and most dyno tuners do not want to take the extra time to do this at a MC event. Think profit through volume at bike events.
I am in no way an expert and know enough to be considered dangerous, but this is the way it was explained to me by a dyno tuner.
Old Jun 14, 2012 | 06:45 AM
  #2550
JustDennis's Avatar
JustDennis
You may not be an expert but you are correct sir! Having said that, there are several tuners around here who use and like the PV. I think it just what they get used to using.
