Power Vision Information Thread
Old Dec 3, 2011 | 05:54 AM
  #1521
RLE's Avatar
RLE
Are they using the same base maps as the power commanders?
Old Dec 3, 2011 | 07:03 AM
  #1522
whittlebeast's Avatar
whittlebeast
No, the the maps are totally different. In the case of most of the early bikes, the fuel maps are TPS based similar to the PC3 and PC5 but most of the later BT bikes are MAP or load based. All of the Sportsters are stuck with TPS based fuel maps right now.
Beast
Old Dec 3, 2011 | 08:56 PM
  #1523
clbking's Avatar
clbking
Just got my PV for my 2011 RK. According to Jaime at Fuel Moto, Dynojet eliminated one step where you have to store your stock ECU configuration before flashing your custom map. Now you just go to custom maa and load it.
Love simple!
Old Dec 4, 2011 | 03:51 AM
  #1524
Linville Lion's Avatar
Linville Lion
Originally Posted by turtle2
Doesn't look like anybody wants to explain smoothing, and when to use it?
Its not in the Help section either.
I have been using it for some time. I do not know if it is correct, but it certainly runs well. After a VE tuning run, I highlight the range from zero RPM to the row past the Max RPM. I have mine set at 5400. I "smooth it" once and use it that way. When you look at the resulting map, it has taken the sharp edges off of the tune. The other thing that I do is to separate the VE tuning from the ignition timing. After getting the VE, I run a check to be sure the timing is okay. I do not just reduce the timing, in fact I use a hybrid timing map from my stage II download and one from DJ. I have two maps. One is for cool weather and one is for hot weather/bad gas.
I am interested in find out what others have done. I know that I made mistakes in tuning after I got the PV and chose to start over with the HD Stage II map as the base and adding the best parts of the DJ map.
Old Dec 4, 2011 | 09:22 AM
  #1525
beasleyiv's Avatar
beasleyiv
So when we're done with VE tuning runs, what then? Do we put the HD O2's back in and turn on adaptive fuel? What about the AFR tables? I set mine to 13.0 for the tuning runs. I guess I'm still thinking in the PCV frame of mind. I think I understand that the VE tables are the real deal, but don't you still demand a certain AFR as a target too? From everything I've read it seems the AFR tables are only used to determine open/closed loop.
From the PCV way of thinking, we used the AFRs to richen or lean the tune. Is it the same here, just after getting the VEs sorted out so you know how much air you're really moving?
Old Dec 4, 2011 | 09:48 AM
  #1526
whittlebeast
All EFI systems are similar in that they all have a target AFRs and a way to adjust the fueling to hit that target AFRs. The thing that changes from system to system is the way you set up the targets and the range of valid AFRs for the system you are tuning.
In the case of the PowerVision that most people are using, you are using 14.6 AFR as your target. You can play with the O2 bias some and push the target to say 14.5 or so, but that is about the limits. You can only do autotuning on your new system. when the AFR targets in the AFR table are set to 14.6 AFR. Once you have the VEs set to hit this 14.6 target, then you can lean on the AFRs at say 70 KPA and above to some other target AFR that your bike is happy with. For example 14.0 at 70 KPA and 13.5 at 80 KPA and 13 at 90 - 100 KPA. The system will make it's best guess at how much fuel to add to hit this new target based on what it learned from the tuning process.
Beast
Old Dec 4, 2011 | 01:43 PM
  #1527
RLE's Avatar
RLE
So is there a dyno guy anywhere that will tune with the pv? Talking to several dealers and shops and they havent heard of it yet, and act like they are scared to death to come close to it. Most likely because it is a new product.
Part of me says to get what they like and are comfortable with dyno tuning. Another part of me says this is a prominent tuner of the present and future and once its been around for a while ill have felt stupid cause I went with a tts or super tuner. Riding around with a lap top bungee corded to the bars or some stupid **** like that cause I want to look at whats going on and learn about it. Meanwhile every dealer in the world only wants to use the pv.
Is this an accurate assessment of what may happen with this tuner? If dyno guys just take the time to learn a new product? Or are forced to due to customer demand?
Old Dec 4, 2011 | 05:25 PM
  #1528
spelk3's Avatar
spelk3
I was the first PV to be tuned at a local shop with a DynoJet Dyno. They were used to tuning with the Power Commander. The tuner had gone to a workshop at DynoJet to learn about the PV, didn't have any problems.
Old Dec 4, 2011 | 05:54 PM
  #1529
editbrain's Avatar
editbrain
Nothing is different from one tuner to the other accept the amount of samples collected in a given time during recording. Some allow access to more parts of the ECM.
There are not any hidden tables in the ECM just because you use a SEPST (which is now a street legal device by the EPA), PV, TTS or the like.
Unless you put a different computer in your bike the tuning is straight forward. VE, AFR, Spark Timing, etc.
Some devices just give you access to more of these options than others. You still need an exhaust sniffer if you really want to tune your bike proper. So any shop with this option should be able to tune a bike given any device that allows access to a stock Harley ECM. I don't understand why shops freak when a device like the PV comes to them. It doesn't make sense to me. If you were to take a computer into a computer repair shop with any Microsoft Operating System that is modern they should be able to fix the computer. It shouldn't matter where you taskbar is located, or what your background image is.
If the shop has a competent tuner that understands the Harley ECM. It shouldn't make a flying flip what device is used to access the information.
Old Dec 4, 2011 | 07:13 PM
  #1530
whittlebeast
Try putting the same VE table in the front cylinder as the rear cylinder. Go for a short ride and then look at the logs comparing the front pulse width compared to the rear pulse width. Hidden tables control things like when in the rotation is the MAP read taken. Hidden tables control the fuel adjustment as the intake air temp rises. Hidden tables control the amount of fuel added when the o2s swing back to rich and how long they stay rich before they swing back to lean. There are plenty of them. Some more obscure than others.
Some tuning software exposes more of these than others.
Beast
