Power Vision Information Thread
Any ideas?
VE tables front and rear,
afr fuel table stoich or lamda
front and rear spark tables
each with empty check boxes to thier left? If so I made that mistake once and I just needed to check the boxes I wanted log tuner to apply changes to. Since I have now revised my map twice I checked all 5 boxes and created a new tune! You save it to your comp, opev pv, open the new map you saved and send it to your PV unit.Once it is loaded in pv software load compare file of the map you made yours from, you should see yellow caution icons in the chanels you logged. Flash your ecm with the new map and try it.
The underlined info was not stated in the online instructions @ either power vision or fuel moto's web sites, at least not clearly to me. The new software is supposed to make all this much simpler to use.....soon as I am told! Hope this helps.
80 kpa = .981 (14.36)
85 kpa = .890 (13.02)
90 kpa = .869 (12.72)
100 kpa = .869
Hmmmm, I wonder if this is where my fuel economy is going out the window. What harm is there to increase the 85 - 100 values at 2500,3000,3500 rpms to .981 or .969? This seems to be a pretty narrow area that would not interfere with performance acceleration. Am I missing something important here?
I'm wide open for suggestions/opinions.
When you get to higher throttle openings, "Acceleration Enrichment" comes into play. Others here know more than me about this entire process, but for pure tuning runs, I think it's best to turn off some of the enhanced features that the Delphi ECM utilizes. The tutorial by forum member JustDennis is a good summary. Don't know if this has been helpful or not...
100 kpa = .869
KPA ∙∙∙∙∙∙∙∙∙∙∙ Current AFR (Lambda) -- Stock AFR
30-80 KPA: 14.5 (.99) -- 14.6
85 KPA: 14.0 (.95) -- 14.2
90 KPA: 13.5 (.92) -- 13.2
100 KPA: 13.0 (.89) -- 12.5
______________________________________
As you can see my current settings are fairly close to stock. I think they go so rich for stock at WOT to help protect the engine from owners who might run at that level for an inordinate period of time. I don't, so there's no need, and I even have PE AFR set to 13.0 across the board. I see no reason to go <13.0 (.89) anywhere in the operating range. Try the above and it should help keep you in a good-mileage area more without introducing any performance issues.
