Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
If you are getting requested changes of less than 5% you should be right there, the VE tables are not going to be necessarily smooth. In the end we are really looking for what the motor wants based on what the system is seeying. I have not received any recent emails or maps to take a look at, the last coorespondence is when I sent you a new map for your D&D 2/1 on Dec 5th. You can send your current map to jamie@fuelmotousa.com and I would be more than happy to review it
After going through all the trouble of doing autotune runs till your VE corrections are down to 5% or less, isn't the smoothing function kinda counter-productive?? Does it not screw up everything you just worked for??
Can a person really tell the rideability difference in a smoothed map??
Got my map back from FM and before it looked like a bunch of sharp peaks and valleys. Now it looks like a plateau with some smooth waves in it. I'm gonna auto tune a few more times with this map and be done. Thanks FM!
you do more auto tunes and guess what, the smoothing will be gone so be sure to save this map so you can re install later
This is my point, the whole purpose of doing the the calibration in all the map cells, and one of the reasons for using EFI, is that there ARE indeed differences in the dynamics of the way the engine runs under various loads and rpms. If you're gonna go to the effort of doing the tune runs till you get the VEs down to the last couple percentage points, why would you then moosh them all back together again with smoothing??
Might as well just stick a carb back on it.
smoothing adjusts the odd cell that did not get enough hits from the data runs. imagine 9 cells 3x3, the center one has a spike up or down on the graph away from the flow of the surrounding cells. do you consider that to be correct and leave it or do you blend it to the curve of the surrounding cells. steady throttle, steady speed the load changes and you enter that cell. the afr gets leaner or richer until you leave that cell. the carb was simpler
Exactly, with my map there would be 1 or 2 (for example) in the mid 60's and all surrounding cells are in the low 80's. It would be my guess that these cells did not get enough hits and it would only benefit the map to smooth them to the surrounding cells. The map I sent FM had a few pathes of these cells. Maybe they can chime in on the smoothing process.
I was instructed by Jamie to do a few more auto tune runs with the smoothed map.
The most important aspect when you are smoothing is to have a good understanding on what the calibration/system is doing for a given area, and how adaptive control works vs the O2 integrator. When the ECM is doing business as normal and learning in closed loop it does not apply these learned fuel offsets at the same resolution as the VE table, it block learns over a cluster of cells, and on top of that the ECM interpolates lookup tables such as VE. So on one hand if you have a cell or even an area with extreme high or low numbers it is a good idea to try blending and smoothing along with the surrounding area and it may be more accurate, however on the other hand big peaks and valleys may simply be what the motor wants for a specific combination and that's how its gonna end up. In this respect there is really no right or wrong way, it simply comes down to which strategy allows the bike run at its best. Hope this info helps.
I purchased a CVO Breakout about a month ago and I want the best tune possible without going to the shop to pay dyno guy a bunch of $$, if a unit I can put in/use will do the job just as well (current set up will be entirely stock with some Rush 2" baffle slip ons, but will want to get Vance and Hines 2 into 1 big radius at some point). But that is the question of course. I had a PCV on my 05 Deluxe for 3 years and loved it-used the map put in by Fuel Moto and it seemed to run great (Jamie at Fuel Moto did say that the PCV unit probably wouldn't work for my Breakout due to the small amount of space under the seat, but my local Indy guy said he has installed many of them behind the rear fender). I like the idea of having a device that will allow me to adjust settings as I mod the bike. That being said, I don't understand anything about the "settings"- all those tables and values look like Japanese to me, I suppose I could learn, but I really don't want to if I don't have to. I just want a pre-made map installed and ride. So, my question is basically should I go with a Power Vision, PCV, or something else, trying to get the most bang for the buck at the same time? I do like the ability to gain an extra license to tune another bike- wouldn't mind adjusting my wife's just a bit (has screaming eagle slip ons and everything else is stock). Looking for any recommendations. Thanks.
I had the same feeling: I could learn more, but really don't want to at the moment. I went with the PV2 for my 2013 FXDB and couldn't be happier with it and the guys at Dynojet. They've answered every one of my questions quickly and simply. The thing couldn't be easier to use, and there video tutorials on their website are great.
I plan on more mods later on, so I may have to learn more, but for now with just my stage 1 upgrades, this thing is perfect for me. Good luck.
When I recently download a new tune it asked me if I wanted to reset some specific tables I can't remember what but it gave me an option of yes or no does anyone have an answer that knows what I may be talking about.
