Power Vision Information Thread
Autotune, save, do again and again. Do this until your VE tables show only small changes like under 5% most say, I prefer under 3%....
After that then you can work on decel pop, idle issues if you have any, cold start etc, but VE tables must be done first!!!!!! Get them right and the rest of the adjustments are pretty easy if you had a good base map to start with.
I personally have 13 autotunes plus 15 logging runs so far and am getting pretty close to what I want. You won't need that many I just like to try alot of different things after I get off work to see what the affects are seat of the pants.
Main point: autotune till the VE are the best you can get them hitting every cell possible several times till very little change. Then go after the annoyances.
So just for my own clarity.. I currently have the FuelMoto supplied map Jaime loaded into the PV when it was shipped flashed to the bike, and that is what I am going to run the AT Basic on to get the VE table as dialed in as possible. This will give me the closest tune leveraging the 14.6 cruise range and NB sensors.
Then as I understand importing a map process, when I import the PCIII map from a file saved on my computer.. first I want to "layer" that map on top of the STOCK TUNE When I flash this, it will essentially put me in open loop. (not 14.6 in cruise range, a compare I just did confirms this) and the VE tables and many negative numbers in them in the -12 to -30 range. Mainly the -20 in the cruise range.
Would I then want to do a AT Basic again? Or, since I'm not in a 14.6 mode would that do any good?
Hope this makes sense?
My opinion would be autotune with the current base map till the VE are correct then if its possible load the PC3 map as a compare file and do copy n paste of just guessing timing tables or stoich table to set your open/closed loop areas as you prefer. The autotune in PV will get your VE tables damn close even in basic.
there are several thing that make me think this.
1 doing runs in cold temps vs warm temps (i ride in everything, anytime) am i on crack to think air density due to air temp has an effect on the ve/air flow ? ...sure does seem like it to me (but i am willing to be schooled on this)
2 i can feel a definite improvement seat of the pants....even the guys i ride with on a regular basis think my bike is "quicker now" (actually getting more of a smile factor from this bike:-)
3 looking at the logs and watching for knock events. i quickly learned that more accurate air flow equaled less knock events ( i can also see a big difference running 91 vs 94 gas in regards to knock... i'll deal with that later)
given the points i just mentioned i must say that i would be (somewhat) surprised if i can truly reach a point of "less than 3-5% change" i will still keep trying and if i dont reach that bench mark (fairly easy to do if i do consistent runs) then i am starting to think that....
A i will just have to be happy with what i have and choose the results that feel best.
OR
B perhaps i need to take a real good look at o2 placement and depth.
i can and will grind down my bungs to get the sensors at a more effective depth if i need to, or even move them to the 12mm locations (i have 18mm but can and will drill and tap if need be) .
i do not want to weld in new bungs cause i have ceramic coated pipes (inside and out) and i know that will not be fun to deal with.
i am still a new student to all of this and i know it will be some time before i can consider myself anything but a new student. i do have an open mind and eventually i do become well versed in subjects i take an interest in.
on a side note, after just one run with lower idle settings (bike and pv) i can feel an improvement with first gear ride-ability.
to be honest i am not certain if it is related to running 1000 rpm idle vs the 950 idle i have had since i got the pv or a combination of both.... i think it would be educational to change my idle back to 950 just to see :-)
my posts are getting long winded but i would like to thank everyone who has provided us here with there knowledge... this would not be so easy without it.
if it helps.... i have a 2011 blackline with rush 2-1 exhaust, dkcustoms outlaw breather (and my god those pirelli night dragons are great tires)
I'll be starting with the autotunes on the FM supplied base map tomorrow and see what results that gives me.
This is going to be fun to tinker with to see and feel what works best!
I can see where this will take me... I'll try all the combinations and turn PV tuning into a hobby and then when I've exhausted the AT Basic.. Jamie will be getting a call...
It's a progressive disease they tell me.
