Power Vision Information Thread
I've been able to contnue using PV Log Tuner for spark table fine tuning employing the procedure described by Dynaulv in that post.
I could repeat the steps, but that would just be copying what he already suggested.
I and others have used it since the DJ update confounded the relationship between Log Tuner and the WinPV s/w.
If you notice in Notepad, when you open a .pvv file, and search for the Item name = "VE line you'll see the (Map based/Front Cyl and (Map based/Rear Cyl lines.
[Simply eliminate the "Map based/" term in both lines and save the .pvv file to run through Log Tuner.]
Note in the updated version of WPV when you open a tune in the Airflow VE sections, you see the same reference.
I think it was intended that the .pvv file structure, when updated to relate to the 2014 ECM structure, adding the "Map based" terms to WPV would work;
but, obviously it hasn't; thus the work around suggested by Dynaulv; which gives us continued access to Log Tuner while DJ fixes it.
It works perfectly. Good luck.
https://www.hdforums.com/forum/elect...admin-549.html
Good luck.
Wasn't directed at you...just piggybacking on your post.
The Knock sensor. can be activated not just because of the absolute value but also by the magnitude of the change in value from one cell to the next. I have found that evening out the transitions will generally achieve a much smoother throttle response.
That being said, it a good practice to use the log tuner to see if the new map moved any spark cells upwards that pushed it into a knock region. There's no "magic button" that makes a perfect spark table however smoothing can be a good tool, particularly if you start with a solid table.
For my purposes the "Smoothed" table in the map I referenced several pages back, resulted in outstanding performance once it was copied into my existing map and flashed to my bike. It created almost zero knock events.
Well so much for thinking my engine couldn't be made better. On a whim I decided to create a new map using all my settings and my latest autotuned VEs but with the timing from the map above.
My spark tables were less aggressive in some places and more aggressive in other areas. In general the other big difference was the seamless and smooth transition of spark from one section of the map to another in the map above.
Well after all the autotuning I've done, this one single map change transformed my bike from running strong and sharp to making it utterly rip through the gears as if it wanted to tear the bike out from under me. I've done some additional autotuning on the new map with these new spark tables and its now, remarkably the best I could imagine my engine build could run.
The only last step I'd like to do is run the Log Tuner to check for any knock events. Unfortunately after upgrading the PV firmware and upgraded WINPV, the Log tuner no longer functions with datalogging collected from the PV. I understand the DynoJet software engineers are working on the issue and hope they release a new version of the log tuner soon. For now, I'm just really enjoying the new ripping power of the bike. Now with 38,000miles my bike feels like it has an engine that has been significantly bumped up in low and high end power. What a pleasure!
Does anyone know how this spark table was created? It appears as though it was done by a computer given the many cells that have spark advance values with fractions.
Just like with too little timing, one can have too much. The IDEAL timing would be timing that fits the MBT (maximum brake torque) for any given engine at a certain load and rpm. One simply can NOT find MBT while road tuning. PERIOD. WHile road tuning... how can you even begin to tell what timing made the maximum amount of power?
So, for road tuning... I agree 1,000,000% with stailjim61... run the timing tables from the canned map and adjust simply for ping. There is NO computer simulation nor program that can dial in one of our bikes to make MBT. One should investigate how OEMs make timing tables for real. I have slightly. It's all about pressure transducers installed in the heads.... of which we do NOT have at any of our disposal, even Steve Cole, Nor Jamie Long!!!!
Some dyno guys DO dyno a bike to get close on the MBT. This takes a Superflow dyno or a Dynojet 250i with the additional torque arm set up... and... to make one's life a tad simpler, a PC3 as the 'timing tool". A PC3 would be used with a bike that has a map installed using a flash tuner like TTS, PV, SEPST and then throw it on the wheel and for each and every cell that matters... adjust the timing live with the PC3 and do a tug... over and over again.... using like .5 degree increments.
This is done by very few tuners as it is extremely time consuming! Most base maps from TTS and PV are decent approximations. Simply increasing timing until it pings is NOT the best for power, nor is it the best for the bike. What 'tuning' really is all about is trying to get the most power out of an engine... all the while obtaining the best possible 'street manners'. Running things to the ragged edge of things... with no possible benefits is simply silly, IMHO.
My personal dyno does NOT have a torque arm. That costs $1000s more as an add-on. I may get one at some future date, tho.
And... as far as smoothing to a gnat's ***? That doesn't really do much either. Most times, we will want to acheive maximum power and the tuner will see each cell IS a tad different, because we don't have the ability to 'smooth' for each KPA, we go in increments of 10 points. An engine can and does want different timing at say 50 MAP at 3500 rpms than it does at 59 MAP.... all of which is in the 50 MAP cell. Let alone what the engine may want or need at 64 MAP. Smoothing eliminates these obvious changes in what the engine needs and.... wants.
So... there really are different arguments here... not just one 'correct' path. I am just giving what I have learned over the years from BEFORE I had an actual dyno and could play more often. Most top tier dyno guys will state that smoothing the timing tables is a waste of time. I am now-a-days in that camp, also. Giving an engine what it needs/wants is more important that having an advance curve that is carried out to 100ths of a degree.
A couple years ago, I saw the actual Delphi program to 'tune' a Delphi ECM with. Did any of you guys realize there are actually timing tables for each and every gear? Well, there is. ANd what we GET is some kind of best guess approximation of all of that, condensed into a single table, instead of six. Sooooooooo.............
I am really going to side with stailjim61 on this.
