Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Wolf No problem.
I am glad you found something to get your mind around.
I read it more than a few time and Go back and reread the PV manual too it helps to understand what you need to do first and following the Steps in order is a must when you are first learning. I am still learning also.
One thing to remember stage 1 is not a lot different than stock but Just enough it needs a little tweak here & there.
Trust the PV It's a great tool But you must understand it to use it.
I recently removed my 255 cams and installed the Andrews 57h. I love these cams, they come alive at 2500 rpm on up and I get really good response in the lower rpm areas...HOWEVER!!!
The bike runs like crap when the engine is cold.
The symptoms?
Cuts out through the lower rpm ranges (from idle until about 2300 rpms)
Sputters off idle when taking off.
Once the engine reaches operating temperature it runs fine so was looking at the warmup enrichment table and was wondering if adjusting this would help.
The symptoms?
Does anyone have any experience with this table?
Thanks
Dave
are you using the same 255 tune file for this 57H cam?
I would try this before fooling with the enrichment.
take the 10 and 20 kpa VE columns from 750 through 2000 RPMS and increase those numbers by 10%. See if that makes a difference when it's cold.
I'm also assuming you've done some auto tune runs to dial in your VE tables correct? If you haven't then ignore the above and get after dialing in your VEs as it will run like crap until they're dialed in.
Can you post your map up here so we can look at it?
