Power Vision Information Thread
Old Sep 10, 2014 | 01:15 PM
  #6491
JustDave13's Avatar
JustDave13
Originally Posted by UltraNutZ
yikes.. yep. increase those 2 columns by 10% and see how she reacts.
Thanks, do you mean throttle position percent or kpa? My VEs only show tp percent
Old Sep 10, 2014 | 01:21 PM
  #6492
UltraNutZ's Avatar
UltraNutZ
sorry yes..
the 0 and 2 columns. actually increase the cells from 750 to 3000 by 10%. flash it and see what she does
Old Sep 10, 2014 | 01:25 PM
  #6493
JustDave13's Avatar
JustDave13
sorry yes..
Got it, thanks for the help. I'll wait till later on this evening when it cools down some.
Old Sep 10, 2014 | 03:08 PM
  #6494
nhrider1's Avatar
nhrider1
No. I build tunes from scratch using the stock map as a starting point.
So the warmup settings would be set for a stock 2013 103.
Wow...that's the long hard way to do it. Do you set timing and AFR by trial and error?
Old Sep 10, 2014 | 03:22 PM
  #6495
WolfAngel's Avatar
WolfAngel
Talking
Originally Posted by Smokey Stover
Ok good,So after resetting the PV, all 6 custom tune slots were empty,right. With the PV hooked up to your PC, you opened the tune you want to use, Then before using "Get Tune" to load it into the PV,Use the "Powervision" button on your toolbar, The dropdown menu has, "Update Tune using PV" you used that,right? I'm just trying to be clear. You should then have a fresh clean updated tune to "Get Tune" loaded into the PV to flash your ECM.
SMOKEY, U R DA MAN!!! I have not tried AT yet but I have inputs back! Trip center is back! Etc..Etc..Etc.......Got my excitement back again! Thanks a ton!
  #6496
JustDave13's Avatar
JustDave13
The long way? I think it's fun.
The timing is based off the stock timing tables, I think the fuel maybe based on a modified stock map I got from Dynojet
If you look at my map the fuel is dialed in for performance, the timing was increased 3 degrees across the board and pulled in areas for pinging.
Both were smoothed.
The bike runs like a raped ape and I still have some tweaking to do.
Old Sep 10, 2014 | 03:27 PM
  #6497
WolfAngel's Avatar
WolfAngel
Originally Posted by Smokey Stover View Post
Did you do the reset posted by UltraNutz?https://www.hdforums.com/forum/igniti...l#post12897968
Not to forget a big shout out to Nutz for the great reset info!
Old Sep 10, 2014 | 03:41 PM
  #6498
UltraNutZ's Avatar
UltraNutZ
unless you're sitting on a dyno and troubleshooting an issue like he has, there is no other way to do it but trial and error unless you're going to call someone up and say "hey can you send me a map please" and hope it's close to what you need. Take a look at his map.. do you have a better suggestion?
Old Sep 10, 2014 | 03:46 PM
  #6499
nhrider1's Avatar
nhrider1
Both were smoothed.
I won't argue with success, but both timing and AFR look very conservative to me (for performance).
I built a map manually for a bike without O2 sensors and it took a lot of trial and error to get it close to right. Lots of variables to deal with.
I guess being able to dial in the VE's first helps a lot.
Old Sep 10, 2014 | 04:07 PM
  #6500
JustDave13's Avatar
JustDave13
I wouldn't have attempted to do this without getting the VEs locked on.
If I had a dyno and a 3 gas sniffer that might be different.
I'm not done with the tune yet, I'm going to play with the timing a little and maybe the fuel. I could run the bike in open loop but I'm trying to balance performance and fuel economy.
Right now I just want to clear up that warmup issue.
