Power Vision Information Thread
Key Features
- Allows the factory ECM to interpret and use wideband o2 sensor signals*
- Target fuel table from the calibration/tune is achieved in real time
- Retains OEM closed loop, adaptive fuel control strategy
- Learns and uses VE table corrections as you ride
- Does NOT interfere with dealer diagnostic/service tools
- Includes OEM style connectors to plug into factory o2 harness, either 2 or 4 pin versions
- Fits 2007 and newer Harley-DavidsonŽ Bikes
Key Features
I guess we'll have to agree to disagree lol. I'm not into grandstanding or committed to standing on any particular soap box. Your highlight does say the connectors plug into the factory harness (not the sensor themselves). If you had to use both sensors at the same time, it would mean that all exhaust systems would have to have another bung welded into them.
Take care and have a great day!
You do need both 18mm and 12mm bungs to install TT.
See this thread:
https://www.hdforums.com/forum/new-r...d-dynojet.html
Louis
You only need 18mm bungs and the WB O2 sensors for TT to work.
The NB O2 sensors are disconnected and no longer used.
According to Brian at Fuel Moto "the Target Tune system is plugging into the wiring harness where your factory oxygen sensors used to be connected to. For the most clean install I would remove the factory oxygen sensors and install 12mm plugs in their place".
Hopefully Jamie or Dyno Dan comes across this post, as they are likely the only ones that may be able to answer this question.
Perhaps a quick overview would help as it regards to the tools available to correct VE tables and build solid calibrations using Dynojet's Power Vision:
Tune type > Process > Hardware required
Regular Tune > Autotune Basic > no extra hardware needed, uses stock o2's
Regular Tune > Autotune Pro > need Autotune wideband controller and sensors
Regular Tune > Autotune Pro > need Target Tune wideband controller and sensors
Target Tune Tune > Autotune Target Tune > need Target Tune wideband controller and sensors
I hope I didn't muddy the water, it's hard to convey some of this stuff with all the distractions in a day.
