Power Vision Information Thread
On that note, the stock HD tunes on stock bikes are purposefully "safe-a-fied" for new riders. For example, all power is removed from the lug zones of map. This prevents new "green" riders from messing up the motor during break in- too much power in this zone combined with excessive lugging can cause things like flywheel shift. With power removed from this zone, lugging will not have enough bang to cause harm. But this also makes the bike feel slow on take off and roll-on from cruise in the lower rpm's - So this is what I'm just repeating, if you don't agree then don't shoot me ok?
But all this leads me to firmly understand that if you want a decent tune, work with a decent tuner or learn the system and tune yourself. the AT basic is only going to help with things like economy, idle and cruise. It will not help with performance gain or things like decel cracking / pop. Using AT basic with a good working performance-oriented tune can actually un-do the performance aspects of the tune.
The "Adaptive" setting can also tame a performance tune by changing the fuel trims to a more economical value- that is mainly what it does. To stop this from happening, run the tune in open loop only by setting AFR table values outside the Closed Loop Lambda range. This will allow you to leave "Adaptive" enabled in the ECM, and Adaptive Spark will still work as a safety measure against spark knock. But Adaptive will no longer alter the fuel trims due to preventing Closed Loop operation. Again just repeating what I was told.
I was told this as well- If you do not want to save AT yet but just want to see the changes AT wants to make within the PV2, go to the "More" screen after the AT session. Select LCORF and LCORR to see AT's suggested VE changes for front and rear cyls.
FWIW - i was going to try this out over the weekend / no time yet.
There is (ET) engine temp reading, as I have been told this sensor is front left by the cylinder.
There is also Head Temp I believe this labeled (HeadT). Where would this sensor be located?
PV logs are saved in .csv format, logs can be viewed in the Dynojet Power Core software which can be downloaded here
http://www.powercommander.com/downlo...5449.19123.exe
A .csv is a very general format, it can also be opened in most spreadsheet programs including MS excel
How are you getting csv log files created in PV to view in CS3 Data Center? I'm tech guy so I do understand the csv format and using Excel, but I have no idea what to really look for as far as tuning from logged data in the Excel views. Lots of data in lots of columns. What's important to you in these log files when tightening up a tune for performance?
What I was trying say was using the Quick-Tune option on the fly has its uses but doesn't actually Flash the ECM with the changes. They'll reset If/When that 'base' tune is selected to AT or pulled out of the PV to compare in WinPV. The QT adjustments will persist in the buffer until another tune is flashed or adjusted +/- with QT again. I wish I could explain the way I think but I confuse myself sometimes lol.
