Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
So my logs seem to show a higher than average IAT (160-190). I have checked for loose connections, and the sensor doesnt appear to be bad so I dont know if the readings are false, or actual. I got to thinking (scary I know), I have the big Kuryakyn Smoked saddle shields and I am wondering if that right side shield is deflecting more of the rear cylinder heat back into the intake..Ideas? I am still chasing down a really bad dropout when I blip the throttle from idle... like when you are sitting at a light.. and you blip ...it drops out...it if I dont blip but rev a little slower its mostly fine. It doesnt seem to do this until it start to get warmed up. Cold start up, it doesnt do it at all...
Anyway.. IAT temps.. what do you guys think..
Glen
I can't remember what my IAT temps normally run when it's in the 70's/80'sF here in New England, but I do remember being surprised that the intake picks up a significant amount of engine heat that warms that air quite a bit above ambient temp.
What do you guys think about a S&S A.C. Tear Drop with my Powervision?They make one for late model Touring ,got mine for $190. On Amazon free ship and easy install!
I love the old school look, but there is a new one with a couple of air vents toward the rear of the teardrop. I'm not sure what one your talking about, but if it's S&S it's gotta work well, and I like the looks of both but the one without the vents better.
Greetings. I have a 14 Softail with a PV tuner. Once in awhile when I come to a stop the idle does not instantly go down to 1000 rpm's. Rather it stays at approx 1250 rpm's for 10 or 15 seconds before it slowly goes down to 1000. Not sure this is even a problem. Could it be normal under the right conditions based on what the sensors are seeing? There are no issues with the throttle cables. Thanks.
I'm trying to help out a buddy with pc v. when I download the software from dynojet, there are no maps. it says they will be copied to a new location but the "maps" and "copied maps" folders are empty. this is with window 10 if that matters. I know its not a pv but thanks for any help.
