M8 problems
Old Oct 2, 2017 | 05:05 AM
  #931
badcooky's Avatar
badcooky
Originally Posted by splattttttt
my bad. Was a while ago that I had read something relating to the MoCo's new venture involving assembly and manufacturing of their machines. And thought at the time I posted, that it was a 100% effort taking place in India.
Turns out I'm partially right. http://www.motorcycle-usa.com/2012/0...ikes-for-less/
Apology accepted Splaaatster, shoot I've been to India a few times and what a shambles it is.
Old Oct 3, 2017 | 09:14 AM
  #932
frankegd's Avatar
frankegd
Originally Posted by frankegd
My LCD thermometer on the dipstick showed 312 F while doing about 55mph on the interstate. I also have some oil I am going to have analyzed. It has been in the engine for about 10 days/ 200mls. We shall see what that says.
And BTW, it was dark, in like DARK!
FrankEGD
Broke new engine in (3k mls), works fine so far.
just FYI:
On repair order/invoice for original engine, tech stated: FRONT OIL JETS LOOSE, REAR OIL JET MISSING ONE SCREW.
Engine came with new oil pan, which according to dealer is not normal.
I guess missing one screw was justification to replace engine and pan. Where ever the screw might have end up. Tech did not tear into engine any further, just sent it back.
Thank you
FrankEGD
Old Oct 3, 2017 | 09:26 AM
  #933
Max Headflow's Avatar
Max Headflow
just FYI:
Thank you
FrankEGD
New oil pan would be normal if a screw was missing in the motor..
Old Oct 3, 2017 | 11:57 AM
  #934
Breakout110's Avatar
Breakout110
They increased the diameter of the crank pin to make it stronger.. Kinda wonder if some of the stage 3/4 motors that have blown up haven't twisted / spread the cranks tho.. Spec for runout is still loose.. 12 thou for in case. 5 thou in the stand.
Mine is about to go. Vibrates pretty bad above 3700.
It’s going into a performance shop for a build.
They will check everything as it’s disassembled. I’ll post the crank runout.
If anyone is doin Stage 2 and higher on a Twin Cam. Have the bottom end done.
Old Oct 3, 2017 | 12:33 PM
  #935
TomcatCV62's Avatar
TomcatCV62
Well, Jessica really gave you a shot in the comment section. Nice bike, I love it.
Old Oct 3, 2017 | 12:39 PM
  #936
QNman's Avatar
QNman
For stage 2? That's serious surgery on top of a cam, isn't it?
Old Oct 3, 2017 | 01:55 PM
  #937
Breakout110
I know, right?
I ride the **** out of my bike.
I should also link the track passes from YouTube on here.
That will show her😋
Old Oct 3, 2017 | 01:56 PM
  #938
Breakout110
It is, but the crank is weak.
Old Oct 3, 2017 | 05:38 PM
  #939
Breakout110
I’m going to start a new thread on my 117” build.
Old Oct 6, 2017 | 07:35 AM
  #940
frankegd's Avatar
frankegd
FrankEGD
Good morning,
here are the lab results about the oil. Nothing out of the ordinary, according to the lab tech.
Thank you
FrankEGD
File Type: pdf
