FLH starter switch wiring
I am trying to sort the connections from starter and kill switch into the wiring terminal block and onward. I do have the manual and wiring diagrams- I have been referencing both 78/79 and 80-84, but the images are a bit blurry.
My question is, what is the second lead of the starter switch connected to? One side clearly goes to terminal 4 and from there to starter relay - makes sense. On one diagram it looks like the second lead from switch is connected to the white lead from kill switch. This is the way I wired it, but it doesn’t seem to work. This white lead goes to the coil. I am thinking that it should actually be connected to the grey lead of the kill switch, connected to terminal 5, and from there to the ignition relay. This makes much more sense- pressing starter then sends 12v to starter relay.
Can someone please confirm this either way?
Thanks in advance!
I can attach images of diagrams and leads if that helps.
switch, the 12V feed comes from Grey wire to terminal 5
Item 26 is kill switch,22 is start button
My next question is about kill switch is standard handlebar controls. As mentioned I have installed aftermarket GMA brake and clutch levers that include 3 momentary switches (see pic below). These are referred to as Normally Open (NO). So, the switch I am using for kill (guessing this is RUN-OFF in troubleshooting section) is open unless pushed. So, key question is does the stock kill switch operate in “normally closed”? If so, it would be completing 12v power to both coil and to momentary starter switch when it is pushed to Run. When pushed to “off” (open) it would then disconnect 12v to coil, presumably killing engine. By default, there would be no 12v available to starter switch unless this switch was closed.
This would make most sense to me- can you confirm? Unfortunately I don’t have the stock controls any more so I can’t validate myself. I can potentially replace the NO momentary switch with a latching push button which can operate either open or closed.
thanks!
As for as the kill switch goes, it's a rocker switch. Not a momentary off switch.
carl
TwiZted Biker, yes, I have wired relay for high/low beam which works. The '81 has a low amp starter relay (Bosch style) already, so I think it should work if I get the connections right.
Carl, I have the factory service and parts manuals in PDF. Below is the wiring diagram for 80-84, as well as the one for 78-79, which is actually a bit more legible.
I believe that I have wired correctly - second wire for start switch connected to white wire from kill switch. The problem (I believe) is that the kill switch needs to be a two way switch (like rocker in stock controls) that is normally closed (RUN), therefore providing 12v to white side and therefore strter button. I can source a latching switch (on-off) or a Normally Closed momentary switch that would fit into the GMA housing. Or, on a completely different track, I also have a lever action starter solenoid and matching relay that I could install that would bypass all of the handlebar wiring. That said, I believe I would still need to sort the kill switch.
Can someone confirm that the RUN position of the Kill switch is closed? Based on everything I know at this point I am 99% sure...
Also, you should not have to pay for old harley manuals in PDF - Rat Bike Service has a page for downloads:
https://www.ratbikeservice.com/HD/in...ervice-manuals
thanks for all the support!
