Progressive Drop-In Lowering Kit for Night Train
Old Aug 2, 2017 | 02:43 PM
jamzcl's Avatar
jamzcl
Default Progressive Drop-In Lowering Kit for Night Train
Hey all -
I just ordered the Progressive Drop-In Lowering Kit for the front end of my '07 Night Train.
Right out of the box does the kit lower the front end a certain amount or do you cut the PVC spacer no matter what?
I have seen some pdf's of the instructions but it doesn't say how much of a drop it is out of the box - all I've seen is it says the PVC is 4.5" for my bike, but how much drop does that give you?? Just trying to avoid some trial-and-error as I only want 1-1.5" drop.
Thanks!
Old Aug 2, 2017 | 03:28 PM
dsalazar63's Avatar
dsalazar63
I used this setup on my 2005 Deluxe. You have to cut the pvc to achieve your desired height. Just make sure you cut both sides the exact same length. make sure the cuts are straight, then sand down any roughness. I hand never dropped the forks on my bike and honestly the hardest thing was removing and replacing the nacelle. Other then that, piece of cake.
Old Aug 2, 2017 | 05:35 PM
jamzcl's Avatar
jamzcl
Thanks brotha!
Old Aug 2, 2017 | 07:07 PM
jkinner's Avatar
jkinner
Don't over fill the fork oil. Just a friendly reminder.
Old Aug 3, 2017 | 01:24 PM
imjdoggie's Avatar
imjdoggie
dsalazar63 what do you mean when you say the nacelle was the hardest part?
Old Aug 3, 2017 | 04:04 PM
dsalazar63's Avatar
dsalazar63
The chrome housing behind the headlight. On the Deluxe, the nacelle and the auxiliary lights have to come off and go back on in a specific order or it's a pain in the *** to get everything to line up properly.
Take your time, take pics as you take things apart. Refer back to them....you won't have any problems.
Old Aug 4, 2017 | 09:42 AM
jamzcl's Avatar
jamzcl
The kit should be showing up today or tomorrow so I might have some pics to follow, if I remember to take them during the install
Old Aug 4, 2017 | 03:15 PM
dsalazar63's Avatar
dsalazar63
Looking forward to seeing the pics and finished job.
Good luck !
man1987
Mar 27, 2016 11:05 PM
razorback84
Softail Parts
Sep 26, 2012 10:31 AM
moonshined
Jun 13, 2011 01:06 PM
SD Night Train
Mar 19, 2009 04:26 AM
Plato
May 31, 2008 10:20 PM
