brake pad bolt
Old Jul 7, 2022 | 02:43 PM
rollingjones69's Avatar
rollingjones69
6th Gear
Default brake pad bolt
Does anyone know what size socket fits the bolts circled in picture. They're the bolts that secure brake pads 2003 Fatboy. Hopefully not some special size. Thanks!
Old Jul 7, 2022 | 02:58 PM
MURPHCC1's Avatar
MURPHCC1
IIRC 6mm 12 pt
Old Jul 7, 2022 | 04:02 PM
touchdown's Avatar
touchdown
Just take your sockets out and try a few when one fits use it.
Old Jul 7, 2022 | 04:13 PM
rollingjones69
6th Gear
That's what I was doing unsuccessfully LOL That's why I asked before I boogered it up.
Old Jul 7, 2022 | 04:15 PM
rollingjones69
6th Gear
Originally Posted by MURPHCC1
IIRC 6mm 12 pt
Okay, so it is a 12 pt and metric you think?
Old Jul 7, 2022 | 04:58 PM
stillkickin''s Avatar
stillkickin'
On my Deuce those are 1/4" 12pt. Don't try it with a standard socket, that will bugger it.
I never understood why everything on the forks were metric except those two. Just bizarre.
Old Jul 8, 2022 | 01:28 PM
hattitude's Avatar
hattitude
I just checked both my 2003 Heritage and 2001 Springer and the pad pins for the rear calipers on both take 1/4" 12 point sockets..
I recently did a brake job on the '03 and that's what I used...
The #44314-00 pad pins were used in various models, front and/or back calipers, from 2000 to about 2007...
I also just checked my 2003 service manual, and it calls for a 12 point .25" (1/4") socket for the pad pins, and to tighten them at 180-200 inch pounds.
I noticed while looking up the pad pins in the service manual, the caliper mounting bolts are listed as 10mm 12 point... go figure...
FWIW... a 6mm 12 point is 0.23622", so it's just a bit smaller than 1/4"... If all you have is metric 12 point sockets and a 6mm 12 point fits, use it, but I wouldn't force it on to make it to fit. I'd buy a 1/4" 12 point for the job... a 7mm (0.275591") 12 point would be too big and probably bugger up the pad pin head.
Old Jul 8, 2022 | 02:05 PM
rollingjones69
6th Gear
Very GOOD info and very accurate!! Sad part is, I have factory manuals, but there's no way you could've convinced me that would've been in there. Thanks, I really appreciate it!
fatbobsd
Aug 7, 2015 08:36 PM
rclare
May 27, 2010 08:38 AM
ballzy
General Topics/Tech Tips
Apr 30, 2009 07:10 PM
06Roadglider
Jun 22, 2008 04:07 PM
mac8985
Jun 29, 2007 09:53 AM
