"DYNO" Numbers For SOFTAILS
Old Apr 19, 2009 | 12:52 PM
  #121
edeluxe07's Avatar
edeluxe07
Stock 96" motor, V&H BSS, Thundermax ECM, K&N filter:
72 hp
84 ft lb torque
Old Apr 19, 2009 | 02:14 PM
  #122
imrotton2's Avatar
imrotton2
98model ultra cruiser 96"s&s , super g carb , 2/1 sampson pipe
Old Apr 20, 2009 | 09:16 PM
  #123
hardhead's Avatar
hardhead
Just had a dyno tune done. I've got a stock 96" with AN Big Sucker, Bassani 2:1 and a pcIII. The red line is me tuning it myself and the blue line is what was gained by tweaking it on the dyno.
Old Apr 21, 2009 | 11:10 PM
  #124
Crazy Canuck's Avatar
Crazy Canuck
Just got mine dynoed last week and got 96.55hp with 105.73tq out of my HQ 95". And I haven't started playing with my ignition box yet. I'm very pleased sore far. Couldn't get a print out cause my tech is too cheap to get new ink cartridges. LOL
I'll post the print out asap.
Old May 8, 2009 | 06:17 PM
  #125
fat15th's Avatar
fat15th
2005 annv.fatboy ,factory 95inch, andrews cam, pcIII, v&h bss, zippers hi flow air cleaner, bored throttle body, dynoed by joes cycle 92hp 102tq thinking about a 2 into 1 fatcat for better numbers down on the low end
Old May 9, 2009 | 08:37 AM
  #126
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
95", 211 Cams, Headwork, Rinehart 2-1, hand matched rings, S&S adjustable push rods, 3 angle valve grind, vitron seals.
Uncorrected at 6000 above sea-level with red line being 2-1 pipe blue line is a 2-2.
Old May 9, 2009 | 03:11 PM
  #127
fxstbharley2008's Avatar
fxstbharley2008
Smile Dyno jet
08 RockerC
HP = 91.59
Torque = 102.66
103ci
.030 head gasket
211 cams
V & H Big Radius w/ 1/2 Baffle
sert custom mapped
Old May 11, 2009 | 09:01 AM
  #128
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Originally Posted by fxstbharley2008
08 RockerC
HP = 91.59
Torque = 102.66
103ci
.030 head gasket
211 cams
sert custom mapped
Like to see the dyno sheet on yer' bike. Can you scan and post?
Old May 11, 2009 | 09:05 AM
  #129
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Look at the dyno I posted above. Our builds are similiar. I'm running a bunch of compression to offset my high altitude but the graph I posted shows the BSS vs' the Rinehart 2-1.
The line is decieving. The BSS was stronger than horsemeat wide open but the 2-1 Riney gets there so much quickers with a steeper curve its almost night and day.
If you can live with the crackling raspy outlaw sound of the BSS do a 2-1 anything. They work. Better.
Old May 11, 2009 | 08:35 PM
  #130
6165hd's Avatar
6165hd
Default First dyno tune
Ok, Did the first dyno tune....... hope to get the chart scanned and posted.
running a 2-1 v&h. 103 stage II,255 cams/ stock heads. Finished at
max power 90.55 Max Torque 97.13.
Air/Fuel look more even that what I had before the run. I was definitely running lean.
Any feed back appriciated... could it be better...?? We always want more,more, more......
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
