"DYNO" Numbers For SOFTAILS
Old Mar 7, 2010 | 06:26 AM
  #261
VooDoo13's Avatar
VooDoo13
2006 SE FatBoy CVO ,103", Stock cams (253), Side Shot pipes, Heavy Breather, Tuned with TTS Mastertune on a DynoJet In SAE.
Also converted it to O2 sensor.
103HP/104TQ
Thanks Doc @ HDMD & Dave @ JD cycle works.
Old Mar 7, 2010 | 08:35 PM
  #262
sgod1100's Avatar
sgod1100
121hp/108tq
Old Mar 8, 2010 | 01:10 PM
  #263
roadkingharry's Avatar
roadkingharry
I got my '06 FXST (88 cu.in) dyno'd on Friday (3/5). Internally,the engine is stock and it has a carburetor with a Kuryakyn hypercharger and Samson exhaust. I don't know if the carb was re-jetted, but I'll find out when I do some engine work in the next few weeks. The dyno was STD and performed at a local dealership. There are 4 dealers within an hour of me so prices can be competitive. They charged me $32.00 to do the dyno run. The max HP was 68.63 and the max. torque was 81.03, not bad for a stock bike. I wanted to have this base run done because I'm going to attempt to do some engine work myself over the next month. I'm ordering an Andrwews 26a cam, the Timken B148 bearings and a Cometic camshaft gasket kit. Not switching to gear-driven cams or hydraulic tensioners, can't afford it right now. I'll also remove the top end and send the jugs up to Scott at Hillside to bore and send back with a new set of those 98" Wiseco pistons and rings. I'll post the new dyno results shortly thereafter.
Old Mar 8, 2010 | 02:11 PM
  #264
Ernie 06's Avatar
Ernie 06
I know i just posted mine but i will post them again on the right tread
Attached Thumbnails "DYNO" Numbers For SOFTAILS-fall-2009-160.jpg   "DYNO" Numbers For SOFTAILS-fall-2009-161.jpg
Old Mar 9, 2010 | 01:09 PM
  #265
newcastlefatz's Avatar
newcastlefatz
Default Miss Loretta
96 heritage nostalgia
80ci stock bottom w/11:1 pistons
andrews EV57
Mega-Flo ported and polished stock heads w/bigger valves
tuned to hell cv
crane hi-4
cycle shack 3" exhaust
90/90 at the tire
Old Mar 10, 2010 | 11:54 AM
  #266
Harp_oon's Avatar
Harp_oon
US 95,6 Hp/110,6 tq
Metric 97Hp/150Nm
SE Springer 2008
110" CVO Twin Cam SE 257 Cams, high comp pistons, V&H Short shots, Supertuner.
Old Mar 16, 2010 | 10:18 PM
  #267
mgmmgm's Avatar
mgmmgm
Default 103" 07flstf, 91.6hp 101.5 torque
Dyno run without afr ( i do not know why)
103 c.i. 1,500 miles on build.
Flat top cast pistons
Baisley street port heads
Roller rockers
9:8.1 compression
Throttle body stock / EFI Tuner = Thundermax with auto tune
Map# 548 adjusted
Cams: Redshift 575
D&D Fatcat 2-1 exhaust std baffle
Doherty Powerpac AC
Fueling oil pump
Mobil 1 20/50 V-twin synthetic
I was in hope of 5 more hp or so. Torque curve is nice though.
Old Mar 16, 2010 | 10:22 PM
  #268
mgmmgm's Avatar
mgmmgm
Red face dyno sheet
Roller rockers
9:8.1 compression
Map# 548 adjusted
Cams: Redshift 575
Doherty Powerpac AC
Fueling oil pump
here is the dyno sheet i forgot to add ....
Old Mar 22, 2010 | 10:56 PM
  #269
Wild-deuce's Avatar
Wild-deuce
01 Deuce
95"
SE Cast flat top pistons, machining by ShortBlock Charlie
Andrews 37G gear drive cam
Stock 07 heads shaved for 9.8 comp with comp valve job by Short Block Charlie
Cometic .030 head gaskets
SE adj. push rods
Late SE cam plate with late oil pump.
SERT
At time of Dyno, stock head pipes with Cycle shack slip-ons and round SE AC
Tear down and Assembly by Me
No new Dyno numbers yet with new exhaust and AC, maybe more HP , maybe less
Dyno'd at 96 HP 102 T.
Old Mar 23, 2010 | 11:47 PM
  #270
djcustom1's Avatar
djcustom1
I got 76 hp and 87 tq with sert, heavy brether And short shot V.H. pipes.
