My head porter (Don) said the same thing. I am trying to get the run file, he said he can correct it. Still don't get it though, what will it show and does it affect anything? Thanks
Torque is figured from a mathematical formula using HP and RPM's. The torque and HP should cross at 5250 RPM's, meaning you will always have the same HP number and torque number at 5250 RPM's. Since your sheet was printed out of scale your torque line is skewed. Just have him print it correctly and it will be good for comparison. If your not worried about it just let it go, it won't change anything it will just be more accurate. If you do have him change it ask him to go ahead and print it in SAE correction and not in STD. SAE is the standard correction factor used in the US. Alot of tuners like to print in STD because it shows slightly higher numbers than SAE. But like I said, SAE is the industry standard. SAE (society of automotive engineeres) corrects the atmoshperic run conditions (mathematically) to 29.23 InHg (99 kPa) of dry air and 77 F (25°C) whereas STD corrects the atmoshperic conditions to 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Basically the system was developed so a person could compare HP in one area (say New York) to the HP a run in another area (Say Arizona).
Thanks HT'er. I've put that info in here several times cause it seems a bunch of tuner's likes to use STD just to get the Higher numbers, but U explained it better and faster.
Same as why some tuners use 5th instead of 4th gear.
One dealer's tuner here uses 5th to tune and the other tuner at the other dealer uses 4th,
Talking on the 6 speed tranny's. I've read that will also bump it up a little.
No problem, hope it helps some members get a better understanding. You are exacltly correct on the gear run as well.
My tuner ran the scaled dyno sheet for me, I added it to the above post.
It's printed in SAE that's good. But the scale is still off, it's even more off now than before. Look at the numbers up the sides, they should be the same on both the left side and the right side.
noticed that also even on the new sheet the lines still cross at about 5300,,, hummmmm...
Ok I looked closer, the 100 HP line is pretty close at the 100TQ line.
