"DYNO" Numbers For SOFTAILS
Old Mar 3, 2013 | 05:05 PM
  #821
Weevil's Avatar
Weevil
Originally Posted by 2011 fatee
2011 fatboy lo with s&s 585 EZ cams/thunder header exhaust 96hp/101max torque.
Come on guys, if your going to take the effort to post the results, please use the SAE results of your dyno tune. Why? Well, SAE has replaced STD and has become the correction factor used by engine and chassis dynos by most independents and all current manufacturers of engines in the U.S. SAE is more accurate because it uses more realistic air temp and barometric pressure standards then STD resulting in less of a correction factor for most testing proceedures. SAE 1349 is the CF recommended to be used by most chassis and engine dyno manufacturers such as SuperFlo, Mustang, Clayton, Dynojet, etc. Many who still use STD are using it because it provides approx 4% higher TQ and HP numbers then SAE.
http://www.hemrickperformance.com/Pa...namometer.aspx
Old Mar 5, 2013 | 10:34 AM
  #822
imrotton2's Avatar
imrotton2
here is my evo softale with 96"s&s
Old Mar 5, 2013 | 03:44 PM
  #823
Weevil's Avatar
Weevil
*Correction Method: Standard (STD) and a 4th gear pull? Name:  shrug.gif
Old Mar 5, 2013 | 04:14 PM
  #824
BlackSpecial's Avatar
BlackSpecial
I haven't been thru this whole thread to see how many SAE or STD dyno sheets there are. The correction factor used is up to the tuner. There's no hard fast rule for either as far as I can see.
The dyno is for tuning and comparing parts. The only valid way to actually compare one bike to another is to have the dyno done in the same shop on the same day by the same operator.
If the only concern is "bench racing" then I guess you could insist on one correction factor or another along with only allowing numbers in a given gear. But you still have the possibility of an unscrupulous operator fudging numbers.
Some of the top Harley performance sites list dyno sheets with both SAE and STD correction (Woods Cams, Horsepower Inc., Headquarters, Hemi Performance Engineering, Revolution Perf.,)
The reality is that the % gains thru modification and tuning is virtually identical regardless of the correction factor used.
Old Mar 6, 2013 | 08:14 AM
  #825
imrotton2's Avatar
imrotton2
whats wrong with a 4th gear pull???? i only have a 5 speed
Old Mar 7, 2013 | 09:39 AM
  #826
PUBA ONE's Avatar
PUBA ONE
Smile New Performance Build
Finally after months of research, I did a "few" improvements.
S & S CNC Ported Performance Heads
S & S 106 Big Bore Kit ( Flat Top Pistons )
S & S 585 Easy Start Cams
Fueling HP+ Hydraulic Lifters
Andrews Adjustable Push Rods
Timken Bearings, new cam chain tensioners, all paired up with my current performance upgrades: Screamin' Eagle Heavy Breather, Vance & Hines True Dual Head Pipes, Screamin' Eagle Performance slip on Mufflers (gutted with Big City Thunder Baffles installed.) Fuel management by Power Commander, Dyno-Jet PCIII USB. Loaded a canned map (temporary). Will have it dyno'd after break-in miles, but according to S & S specs it should come in at around 115 hp & 112 ft. lbs. torque. Now if I could magically make the snow disappear, I could cure the severe "PMS" and start saving for ????????
Old Mar 8, 2013 | 12:32 PM
  #827
jcruz's Avatar
jcruz
6th Gear
Default Stage 1 & Dyno
Had Stage one done yesterday, and here are the results. Not sure if these are good or not. Definitely feel a different, especially at lower RPMs. Config is SE Kit, PCV, Rush 1.75 slipons, and dyno tuned.
Old Mar 8, 2013 | 12:49 PM
  #828
TheTroupe's Avatar
TheTroupe
Nice before and after...
Was it all stock for the before run? What I mean is did you make all the changes at (Pipes, SE Intake, PCV, Stage-1 Download) once?
Old Mar 8, 2013 | 01:13 PM
  #829
jcruz's Avatar
jcruz
6th Gear
I had added the slipons and the PC5. Added the PC due to decel popping. Played with the maps to rid the popping. That's it.
Old Mar 13, 2013 | 04:23 PM
  #830
str8shuutr45's Avatar
str8shuutr45
Default '07 Heritage Big Bore upgrade Dyno numbers
So I just paid for the winter upgrades on my 07 Heritage. I went from a 96 to a 103 and SE255 cams (using the S/E stage 2 pro race big bore kit) and Bassani Road Rage B1 exhaust. The Heritage already had a stage 1 done so it was breathing freer along with Power Commander fuel management. I haven't had to chat with the Dyno tech or a chance to drive to the dealer where the work was done. I paid over the phone and received the receipts and attached dyno sheets in the mail.
The numbers look good but then again this is my first go round at this...what say you?
Attached Thumbnails "DYNO" Numbers For SOFTAILS-07-flstc-dyno.1.jpg   "DYNO" Numbers For SOFTAILS-07-flstc-dyno.2.jpg
