Until I get my bike broke in I would rather get all, if any crap out...Tell me all the other ways of getting the crap that's suspended in oil out of your engine without removing the discharge oil line... snip
If you must be that ****, change it twice !
Seriously though: A) have an extra quart of oil to hand 1) change your oil & filter as usual, 2) disconnect the oil return line (going back to your oil tank), slip on a length of same size hose to it, a foot or so is all, 3) put the other end in a drain pan 4) start the bike and let th dark oil run out until it runs clean [about a quart]. 5) reconnect the oil line and top off the oil tank.
Done deal.
ps: You really do not have to do this every oil change... Harley motors are not made of plastic.
Here is a pic of mine with the d&d fatcat when i first switched over i noticed more bottom and midrange since then i have done a lot of motor work on the bike and left the stock baffle in it. I got 117 hp and 107 ft lbs out of my 95 kit the guy who built my motor says d&d is the only way to go.
Now that's what I'm talking about. What did you use for your 95"? Those are some great numbers.
i used 11to1 cp pistons woods tw9bg gear drive cams the head work and the throttle body was done by jim at cycle visions my final compression ratio was 10.99 to 1 the bike runs like a raped ape and could'nt be hapier
I have a Python 2-1 which is a D&D wannabe. It runs and sounds great. I had a dyno done before the 2-1 was installed but not since and it is my understanding that ANY 2-1 will improve your scoot better low end power (torque).
D D, where did you buy your Black Python 2 into 1 ? Thanks
That is true that any 2 into 1 will improve power, but I am after how much more you will get with the fatcat specifically. It's funny, but I thought your python was a fatcat from seeing your sig pic.
[QUOTE=thealaskan;6395327]If you must be that ****, change it twice !
Thanks for that cocky...Had you read, The return line butts up against the Fatcats headpipe, removing it is impossible without damaging your oil tank. Don't ask me how I know..I like Faast Ed's solution..
