Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 6, 2016 | 08:33 AM
  #3921
LA_Dog's Avatar
LA_Dog
Rod- Nothing in chrome that I know of. It may be easiest to buy a decent used one off ebay, they do come up on occasion, and have it stripped / chromed.
both of these part numbers will fit-
Sportster 1200 68t rear belt pulley and bolts:
2011 XL1200 pulley PN 40444-07 Retail $197 or can use PN 40350-07 as it is still used on the 2013 XL1200 72. the 40350-07 has a machine finish outer rim where the 40444-07 has a black outer rim. both have the machine finish detail on the inner part of outer rim with the black dots. otherwise it's the same sprocket. Sportster bolts are 7/16 - 14 x 1-3/4" PN 3899 hex bolt with locktight patch $1 each
Old Jan 6, 2016 | 09:32 AM
  #3922
Rocker B's Avatar
Rocker B
Originally Posted by rodrocket
Great write up, does anyone know of a chrome version of the 68 Tooth rear pulley
This site has several available, and there's others..http://www.southern-mc.com/puandsp.html
Old Jan 6, 2016 | 09:48 AM
  #3923
LA_Dog's Avatar
LA_Dog
Yeh not too bad on pricing for a custom ordered pulley. if one were to pay $160-ish for the Sportster pulley new (surdyke), plus bolts / washers ($10) and have it stripped / chromed ($100-ish), you'd be almost at the $300 mark anyway.
I'm still lookin for a beater 70t pulley from on 06 dyna so I can see if the 30t / 70t pulley combo will work with the stock 133t belt. it looks *so* close but won't know until I try.
My Target Tune module showed up yesterday - sweet. need to get wb o2 bungs fitted on the VH pipes.
Old Jan 6, 2016 | 11:06 PM
  #3924
_Martin_'s Avatar
_Martin_
Stage III
New headlight for Breakout from Custom Dynamics.
Looks nice but to expensive :-(
http://www.customdynamics.com/trubea...d_headlamp.htm
Old Jan 7, 2016 | 02:48 AM
  #3925
NSR's Avatar
NSR
That's a 7" light. The Breakout uses a 5 3/4" light
LA_Dog, what kind of a headlight are you using? A short ways back in this thread you mentioned that it's an LED. Did you just replace the H4 bulb in the HD reflector? Or something more? I've got one of the Primo LED's on my bike. It's OK, but I'm always on the lookout for something better. I got it for the built-in turn signals.
Also - LA, after switching to your new LED signals up front, were you able to do anything to correct the way your speedo signal indicators flash?
Old Jan 7, 2016 | 08:07 AM
  #3926
Rocker B's Avatar
Rocker B
Scroll down, it's there... 5 3/4" is $429.95
Old Jan 7, 2016 | 08:11 AM
  #3927
JeepXK's Avatar
JeepXK
Ok i'm still learning this Harley stuff, so don't flame me for this question please....... But is the harley sprockets the same as a sport bike? Going down 1 tooth on a front sprocket is like going up 3 on the rear on a sport bike, Just wondering if it's the same on the breakout?
Old Jan 7, 2016 | 11:25 AM
  #3928
NSR's Avatar
NSR
D'Oh! How'd I miss that?
Old Jan 7, 2016 | 12:22 PM
  #3929
HawkerPilot's Avatar
HawkerPilot
2nd Gear
Default From AZ!
I need to put more miles on this!!
Attached Thumbnails The Everything Breakout Thread-hd1.jpg   The Everything Breakout Thread-img_2334.jpg
Old Jan 7, 2016 | 03:52 PM
  #3930
B'stard's Avatar
B'stard
Stage I
Default breakout front forks
Just put some new front fork tubes into my 2013 breakout does anybody know how much oil should these have.Standard forks are 24 3/8" and I put 27 1/2" to corner around tight bends better here in NZ.
Cheers Garry
