Cigarette lighter
Old Aug 30, 2015 | 02:45 PM
ohiobiker's Avatar
ohiobiker
Stage I
Question Cigarette lighter
I have a 08 Ultra Classic...I bought it 3 years ago...since I have had it..my cigarette lighter hasn't worked...any suggestions how to solve my issue?
Old Aug 30, 2015 | 03:02 PM
craigffb's Avatar
craigffb
if the socket doesn't work, pull the outer fairing and make sure the wires are attached.
bigdumbnoitall00's Avatar
bigdumbnoitall00
check the fuse, try a different lighter in the socket, make sure the wires are plugged in behind the socket.
Old Aug 30, 2015 | 04:45 PM
6 gun's Avatar
6 gun
LOL,,, Stop smoking, but really buy a wire tester at a parts house,
and start hunting for electricity.
Old Aug 30, 2015 | 05:10 PM
just plain john's Avatar
just plain john
Turn the key on first
Old Aug 30, 2015 | 06:04 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Had a lighter die on my 99. quick trip to dealer, had one in stock, plugged it in and fine - first tested a lighter from friend's bike in my socket first.
other thing, sometimes the wires are crossed on the backside of the lighter socket (+/- reversed) from the factory. the lighter doesn't care but accessories plugged into the socket do care. And some accessory plugs (phone charges, gps plugs, etc) have a little fuse in the plug.
you didn't give much info other than "it doesn't work"
Old Aug 30, 2015 | 07:03 PM
bigdumbnoitall00
u can get a lighter at any auto parts store for a lot less then the dealer.
Old Aug 30, 2015 | 08:36 PM
Dsm Limited's Avatar
Dsm Limited
Easy diagnosis
1) Remove lighter from socket
2) Use test light to check for power on the center conductor in the socket.
2a) If it has power, replace lighter insert
3) If no power to center conductor, check fuse. If fuse is bad replace. If fuse is good next step
4) Remove fairing front and check for secure wiring to lighter socket.
5) Check for power at the wiring to the center conductor. If it has power, double check connection.
6) Check for good ground at the outer conductor with said test light.
7) If you have power and ground, replace lighter assembly. If it still doesn't work, quit smoking, it's a sign
Old Aug 30, 2015 | 10:43 PM
Texas Rapier's Avatar
Texas Rapier
I have a cigarette lighter in my aftermarket fairing, the only problem I have with it is it keeps falling out and hitting the windshield of the car that is tailgating me.
Granpita
EVO
Nov 6, 2014 06:16 PM
Gordon65
May 29, 2014 11:56 AM
dkparks
Dec 20, 2009 07:16 PM
jandersen5
Dec 28, 2008 03:38 PM
millercm
May 4, 2007 11:05 AM
