LEDs fitted but flash rate wrong
Old Mar 26, 2016 | 01:55 PM
rowle's Avatar
rowle
Default LEDs fitted but flash rate wrong
Hi all,
Just fitted front and rear LED turn signals and they are flashing too fast.
I know now that i need a load equaliser but there are 100,s to choose from and the cost is from $20 to $100.
Any ideas on the best/ easiest way to fix this.
PS - the bike has a full HD security alram fitted and i think this matters as to what i need?
PPS - do i need 2x if i have changed front and rear or will 1x fix the whole system ?
Thanks all.
Rowle UK
Old Mar 26, 2016 | 02:00 PM
brinky52's Avatar
brinky52
6th Gear
This should help
https://www.hdforums.com/forum/touri...tall-help.html
Old Mar 26, 2016 | 02:02 PM
Keithhu's Avatar
Keithhu
You need a load equalizer. Custom Dynamics, Biketronics, all fine, pick one.
Old Mar 26, 2016 | 02:04 PM
brinky52's Avatar
brinky52
6th Gear
Try 1x first. That should do it.
Old Mar 26, 2016 | 05:52 PM
skratch's Avatar
skratch
my cvo came with rear led lights. no problem with the flashing. when I went and added the dynamic ringz up front, then I had issues. got with custom dynamics, and ordered the cvo signal stabilizer (different plug, otherwise same) and that fixed the problem. 3 years later, still no issues.
cd is highly recommended.....
Old Mar 26, 2016 | 09:52 PM
NewAgent's Avatar
NewAgent
I used the Custom Dynamics load equalizer and it works great. Easy install. Plug and play.
Old Mar 26, 2016 | 10:42 PM
twistr's Avatar
twistr
As others have said...you need a load equalizer...Custom Dynamics is a reputable vendor.
Old Mar 26, 2016 | 11:42 PM
goose222's Avatar
goose222
My turn signal arrow on the dash flashes really quick but the turn signals on the bike flash normal. That is how my last two bikes have been so I left them alone. They work just fine.
FLRoadKing
Electrical/Lighting/Alarm
May 8, 2017 04:00 PM
sdeck86
Feb 22, 2015 04:25 AM
digdug
Apr 27, 2014 12:02 AM
huskytamer
Aug 9, 2013 02:21 PM
fatboy1729
May 10, 2013 09:53 AM
