Evolution Industries noisy primary?
Old Jun 30, 2016 | 10:24 PM
jamzholm's Avatar
jamzholm
2nd Gear
Exclamation Evolution Industries noisy primary?
I just installed a Evolution Industries 49 tooth Clutch set up in my 2012 Harley ultra limited. immediately the primary has a whine. I cut off the leading edge of the stock chain tensioner as per the directions of Evolution Industries suggestion but it still has a whine?? any ideas?? Using the fluid they suggested, Type F ATF fluid even tried briefly the harley plus fluid still had the same whine.
Old Jul 1, 2016 | 06:34 AM
Xpressway's Avatar
Xpressway
Id give it some time to work in. Its not so much the oil but the additional teeth on the basket that changes the chains angle on the shoe compared to stock. Mine took about 4-500 miles or so to be barely noticeable.
Old Jul 10, 2020 | 04:04 PM
HOTRODREDFLAKE's Avatar
HOTRODREDFLAKE
I’ve recently done the same thing but am finding a rattling noise is heard at idle and with the clutch out and bike in neutral. With the clutch pulled in the noise goes away. This is on my 18’ street glide with a 49t basket
Old Jul 10, 2020 | 04:29 PM
blue flht's Avatar
blue flht
May be time for a new IP bearing, that was what mine did.
Old Jul 10, 2020 | 04:31 PM
HOTRODREDFLAKE
IP bearing? What’s that, my bike only has 5800 miles on it and it wasn’t making the noise at all last summer. It just started after I did all my work.
Old Jul 10, 2020 | 04:43 PM
rcrankin's Avatar
rcrankin
HotRod, what you have there is the infamous neutral rattle. Welcome to the club!
Old Jul 10, 2020 | 04:46 PM
blue flht's Avatar
blue flht
Inner bearing on the mainshaft coming out the transmisson.
Old Jul 10, 2020 | 04:47 PM
HOTRODREDFLAKE
So Harley knows it’s an issue and it is an issue..they won’t service the transmission to correct it? If tolerances aren’t correct then that’s an issue. Plain and simple.
Old Jul 11, 2020 | 08:58 AM
ratpick's Avatar
ratpick
No, what the bulletin states is that the trans is manufactured to specifications with "tolerances" or ranges of acceptable clearance between gears, and when those clearances happen to mostly be in the same "direction" as it were there can be enough accumulated slack to make a rattling noise at idle when there is no load on the drivetrain. If this is in fact your issue there is nothing to repair. That said if the noise started suddenly, especially after working on primary/installing parts, I'd be suspicious something else might be going on that is a problem.
kino44
Shovelhead
24
Sep 3, 2014 03:14 PM
eugenetaylor
Jun 12, 2012 11:49 AM
wooly62
Jun 15, 2011 11:37 AM
Soarer
Sep 11, 2006 12:40 AM
MntCruiser
Jul 1, 2006 01:45 AM
