Performance baggers
Old Jul 16, 2021 | 11:14 PM
  #1451
TexasD's Avatar
TexasD
Ditched the Wind Splitter for a Road Warrior. Soon to be color matched. Billet Cat will be here next week then off to Dyno
Old Jul 16, 2021 | 11:27 PM
  #1452
HD Bobber's Avatar
HD Bobber
Looks sick!!!! Love the look of the road warrior fairings! Nice move man
Old Jul 17, 2021 | 12:03 AM
  #1453
TexasD's Avatar
TexasD
thank you!
Old Jul 17, 2021 | 06:15 AM
  #1454
NorthWestern's Avatar
NorthWestern
Originally Posted by gartec81
Prodigy rims looking outstanding
They sure do!
Old Jul 17, 2021 | 08:09 PM
  #1455
jesusa.nunez@gmail.com's Avatar
Originally Posted by Dutch66
I have the Galver floating wave disc’s in the front with the Brembo M4 calipers and pads with no problems at all. Important though is not to setup the left and right disc symmetrical. Then you get a harmonic balance that you don’t want. I do not know if this is helping with your problem, but it is worth checking.
What kind of master cylinder are you running with those M4 Calipers?
Old Jul 18, 2021 | 01:32 AM
  #1456
DynaKid94's Avatar
DynaKid94
Got the bucket out for a bit today. Ended up at the usual watering hole...
Old Jul 18, 2021 | 02:54 AM
  #1457
Dutch66's Avatar
Dutch66
The stock one, works perfect. More braking power with less effort because the caliper cup size went from 32mm stock to 34mm M4
Old Jul 18, 2021 | 06:24 PM
  #1458
wow really?? Nice, everywhere I’ve read, I see that I need to upgrade my master which can get pricey. Would you mind sharing where you got those? About to jump on this!
Old Jul 19, 2021 | 12:46 AM
  #1459
Dutch66's Avatar
Dutch66
On older models you perhaps need to upgrade the master ( as I did with my Dyna) But on my 2019 RKS the combined braking system and ABS changed this and it wasn’t needed. The Brembo M4 set I bought at Omniaracing Italie.
Old Jul 23, 2021 | 05:35 PM
  #1460
gartec81's Avatar
gartec81
Slave cylinder decided to crap the bed on my during chain install. Almost back on the road
If you look close under the exhaust pipe you can see the previsions for DIY mid control kit that's on deck.
Looks like I will have to loose my heat shield to make it work but will see when all parts start installing
