??? decell pop
Old Aug 26, 2007 | 07:16 PM
cdale976's Avatar
cdale976
Default ??? decell pop
I have 07 with sert ,airbox and rush 2.0 slipons. bike runs fine but pops when i leave off throttle considerably. Anything i can look for before i take it back to be dyno'd again. the dyno showed 14-1 mix throughout the rpm range when i picked it up.
thanks
Old Aug 26, 2007 | 07:22 PM
steelhead's Avatar
steelhead
Default RE: ??? decell pop
Leaks in the exhaust system would be well worth checking. Some high temp sealant at the head pip to slip-on junction is usually a good remedy.
Old Aug 26, 2007 | 07:44 PM
1947 Knuckle's Avatar
1947 Knuckle
An occasional deceleration pop usually indicates a lean fuel mixture caused by carb or injector set-up,or air leak at intake manifold seal.Your 2007 is not likely to leak at manifold, and uses throttle body injection. Your 14/1 air to fuel ratio would probably be fine for stock intake and exhaust but it is too lean for open exhaust.It would probably run better at 13.5/1.This will be hard to achieve without eliminatingO2 sensors.
Old Aug 26, 2007 | 08:06 PM
Biggin65's Avatar
Biggin65
Are you running factory head pipes. If so when getting off the gas the back jug is sucking in air and causing the O2 sensor to read lean and adding more fuel. Answers....... leave the gas ope just a little dont shut all the way down. or change to a true duel header pipe. I add the Thunder Max programer to my bike with the Auto tuner and they set the softwear up so i dont have any pops on decel....It was worth the money.
Old Aug 26, 2007 | 10:00 PM
cdale976's Avatar
cdale976
ORIGINAL: Biggin65
thanks folks, yeah i have factory header pipes. damn i thought i had all the bases covered when i went with the sert. the guy that did the dyno i know is good from last bike.... i'll give them a call. you would think the sert (sold by hd) would be flexible enough to tune that sort of issue out. guess if they can;t i,ll just have to find a set of slipons that will work. damn if i have the bucks to go true dual now especially since it was the parts guy and tech that said this set-up was a good choice.
live and learn
thanks again
Old Aug 26, 2007 | 10:50 PM
atexn4christ's Avatar
atexn4christ
I have the same problem when I added fuel programmer I though that would cure it. I have about 1,000 miles on my rushes. They were rattling so I pulled the baffle. The packing inside is more than half gone. You may want to check that.
Old Aug 30, 2007 | 11:22 AM
rome304's Avatar
rome304
i was told some decel pop is normal
Old Aug 30, 2007 | 11:33 AM
Softtail Bob's Avatar
Softtail Bob
I don't have the SERT but do have the Rush slip-on's, A/C, and Fuelpak and do not have any decel pop witht he stock header pipes. I would double check the slip-on to header for leaks and then I would see if they could add some fuel in the closed throttle position by changing the SERT settings. Just a thought..
Old Aug 30, 2007 | 11:58 AM
gunrunner's Avatar
gunrunner
Not enough fuel in the 0% throttle setting, youre tuner didnt do his job as good as he should have, take it back.
Old Aug 30, 2007 | 08:32 PM
tom73's Avatar
tom73
Exactly what Steelhead said!
Doublecheck the seal of your pipes with the header. I tightened my down as much as a I could with a 1/2" ratchet and both sides were leaking slightly. Disassembled the slip on's, put a light coating of high temp RTV and reassembled and now they don't leak.
While starting the bike up to let a friend have a listen I could feel the air coming out of the pipes. Since I have fixed I have less popping but I can't say I have eliminated it.
Good Luck
irlm1
30
Apr 22, 2023 06:52 PM
salty_rider
Nov 2, 2014 01:13 AM
BaldHOG1222
Aug 3, 2012 04:32 PM
meyersmp
Feb 1, 2007 03:22 PM
user 6485939
Exhaust System Topics
Jul 3, 2006 11:28 PM
