DYNO Numbers for Baggers???
Arlen Ness Big Sucker A/C
Rush 2.00 slip-ons
Power Commander III usb
71.67 max power
84.58 max torque
looks like AFR is about 13.7 accross the board
Had it done at Salem Harley in Oregon and wanted max fuel economy.
Carbed, rejetted with pro "R" Hypercharger
Andrews Cam
Custom Head Work. Ported Polished, Intake valve opened up 30%, decked.
10.5-1 forged pistons
True Duels with S&S slip on's.
Max power = 105.19
Max Torque= 104.91
Dyno performed at Illinois HD. June 08. (Hope you can read the results)
"Mr. George Ende, Service Mgr. at Illinois HD says with 10 1/2 and no releases but claims 105hp and 91ft/lbs torque? Bulls..t, no way would a bike leave our shop like that. torque can't be that low, something sure as hell ain't right." 708 788-1300 "
Thanks for calling Krusr. Somehow, I knew you would
Last edited by Roadjunkie1; Aug 13, 2008 at 01:15 PM. Reason: Krusr called the dealer and pointed out my mistake. Thanks Larry, you're a buddy for sure.
TC 88 with following modifications:
SE 203 cams
SE ignition
SE intake manifold with open SE K&N filter
Modified Mikuni Flatside HSR 42
Stock heads worked by Pat McNulty of RC Cycles
Re-worked the valve seat profile and did a 3 angle valve grind
Smoothed both the intake and exhaust ports
Trued deck using .30 cosmetic, which did raise the compression slightly
Stock head pipes with Samson Silver bullets
Currently Dyno tuning at RC Cycles, Hayward Ca.
Krusr
Krusr
07 RG
PCIII
Big Sucker
RB Racing LSR 2:1
74.9 HP
88.87 Torque
I will try to attach the sheet
Andrews Cam
Max power = 105.19
Max Torque = 91.73
.I know Mr. Ende from my visits to Chicago and spoke with him personally for about an hour.
Very nice man and I had a very "informative" conversation with him about performance builds and learned a lot.
I see you went from 91.73 ft/lbs to 104.91 ft/lbs of torque overnight.
Way to go.
Oh by the way, your sheet won't open but I think you already knew that.
State what you want, no matter to me.
Your bike, your story.
I'd never doubted you for a minute,
Krusr
I see you gained over 12 ft/lbs of torque overnight.
Way to go.
Claim what you want, no matter to me.
Krusr
Will be with George tonight, has been a good friend for many years and as busy as he is, especially this time of year, no one gets an hour with him. But I will be sure to mention you by name. BTW, George never built an engine in his life. Prior to his position at ILL HD, he specialized in detailing for 15 years.
LOL
