Just ordered a PC V
Old Jul 30, 2009 | 09:15 PM
mazman's Avatar
mazman
Default Just ordered a PC V
I have a fuel pak already, Rinehart slip ons, SE heavy breather. Bike is VERY HOT. What should be the main difference?
Old Jul 30, 2009 | 09:29 PM
street_glider's Avatar
street_glider
Did you get it from Fuel Moto? They provide maps/support for pre-'09 bikes.
I have one with auto tune and my 'hot' ride is nice and cool - and fast. You'll love the laptop monitoring feature.
Search iClick's posts for great write-ups.
Did you order auto tune?
Old Jul 30, 2009 | 09:39 PM
myred55's Avatar
myred55
I Have the PC-V purchased from Jamie at Fuel Moto.
What's "Auto Tune"
Old Jul 30, 2009 | 10:11 PM
street_glider
What's "Auto Tune"
The best thing since sliced bread!
It works with the PC-V specifically. It replaces your stock narrow band O2 sensors with new wide band sensors and it allows the PC-V to 'see' the air to fuel mixture ratios (AFR) as the bike runs throughout all rpm ranges - the stocker is only good for a selective range of rpm. Thus narrow band/wide band.
You basically have a map table with the target AFRs for incremented rpms at incremented throttle positions. This system compares what the bike is 'really' doing and modifies the individual setting needed to achieve the proper AFR results (Auto-Tuning) on the fly.
Now imaging you magically just changes cam profiles - no problem, the AT would see the on the fly AFR change and immediately modify the (trim) settings. Change your exhaust - same thing.
Without AT someone has to manually create the base map to operate your bike. Jamie is great and has some known recipes for exact exhaust, intake, displacement set-ups. These are based upon his dyno testing on these set-ups. So slight variances in each bike are not accomidated. But, these are way better than nothing.
The other way to create the maps is to have someone dyno your bike and thrash the crap out of it for two to four hours and hope their equipment is calibrated and they know what their doing to achieve the AFR results you want. Guess what - change so much as the air cleaner and your bike back up for another round of thrashing to reset the map. Oh, yeah - another $350 for the dyno work, please.
In the end, for me, I don't care what the dyno numbers say. I'm not in the d!ck swingers club. My rearend will tell me when I'm happy with the performance of my bike. I love the great gains I have in PC-V AT set-up, but I have some exhaust improvements and cams (SE255) I think will get me to my own power nirvana. If I'm not satisfied - I'll go to 103" or 107". My PC-V AT will be right there the whole time with zero more $$ invested in injection management/tuning.
Old Jul 30, 2009 | 10:21 PM
luc.who's Avatar
luc.who
Default Past Discussions on PCV and Autotune
Here is a thread on the PCV, talks about install problems and other good discussions on the PCV.
https://www.hdforums.com/forum/touri...tune-info.html
street_glider
Forgot to mention that the AT modules also permit the use of a new PC-V feature that can turn AT on or off. So, you could have a base map set-up for mileage, and use the AT mode for power/cooling. All it takes is a on/off switch of some type mounted on your bike somewhere wired to the PC-V. Switch it when you need either mode.
Research iClick's posts on this topic - they are great threads and very techincally oriented if you thirst for more info.
Old Jul 30, 2009 | 11:47 PM
myred55's Avatar
myred55
Thanks! Sounds like I need to get one!
Old Jul 31, 2009 | 06:09 AM
HD Renegade's Avatar
HD Renegade
Thanks for the info
128auto
Jan 30, 2012 11:00 AM
Rickr01
Aug 10, 2011 01:40 PM
bobby5
May 31, 2010 06:57 PM
RSDUDA
Feb 11, 2010 10:47 AM
1Reaper
Apr 6, 2009 11:44 AM
