Won't accelerate
Old Apr 3, 2012 | 04:55 PM
harleyryder02's Avatar
harleyryder02
4th Gear
Default Won't accelerate
I have a 2002 FLTR 95 in. with nice mods and carburated not injected.
the bike will not accelerate under full throttle.
replaced crank sensor, new ignition, fuel accelerater diaphram, cleaned gas filter. The bike will slowely accelerate to highway speed and you can ride it all day that way but will not do any roll on acceleration at all when twisting the throttle full wide open
It has new plugs, battery, and new stator. The bike has 0ver 68000 miles.
Any suggestions would help
Old Apr 3, 2012 | 10:38 PM
iclick's Avatar
iclick
Some ideas:
1. Throttle cable not adjusted to allow full-throttle at carb or cables misaligned. Apply full throttle with engine off and watch that the throttle cam makes contact with the stop on the front side of the carb, and also that the butterfly valve is fully horizontal.
2. Vacuum port on slide may be plugged.
3. You replaced the diaphragm, but are you sure it isn't leaking? Diaphragm housing may be warped. Remove the cap and try applying some petroleum jelly on the sealing edges.
4. Fuel tank vent blocked or bad gas cap.
5. Fuel hose kinked or clogged.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Slide may be jamming and unable to move upward.
9. Plugged jets or passages.
10. Fuel level too low.
11. Accelerator pump leaking or no output.
Old Apr 3, 2012 | 10:51 PM
1CdnHD's Avatar
1CdnHD
VOES hooked up and operational? Disregard...malfunction on my part.
Old Apr 3, 2012 | 11:22 PM
mkguitar's Avatar
mkguitar
I think by 2002 the voes had been replaced with aMAP on the intake manifold- but I like your thinking, lack of timing retard when the throttle is whacked open.
OP you got a bunch of good tips from iclick, so it's back to basics time.
Is this new, had any work been done recently, anything changed ?
the stuff you did, crank sensor, petcock screen etc was this done after the problem surfaced or before
Mike
Old Apr 3, 2012 | 11:40 PM
hog-doc's Avatar
hog-doc
Sounds like its sumped and not returning oil to the tank. With those miles Ive seen the pump to case o-ring be hard as a rock and crack thus not creating a seal for the pump. Pull the plug on the case and see how much oil comes out.
Old Apr 6, 2012 | 03:25 PM
harleyryder02
4th Gear
Default Thanks guys
I'd like to thank all of you that had some imput because each and every idea was plausable, Vacuum slide diaphragm was the culprit.
Now I have a brand new Crane ignition for sale as I didn't use it.
I didn't realize there were so many things that could slow up a motor.
I even looked into the oil filter thinking I had an Evo filter in it. Oil sumping is a good thing to look into.
Now the bike has had a good going through and should be good for another 68,000 miles
Old Apr 6, 2012 | 03:27 PM
harleyryder02
4th Gear
Everything was done trying to solve the problem
Old Apr 6, 2012 | 03:30 PM
harleyryder02
4th Gear
Default right on target
Originally Posted by iclick
Some ideas:
You were dead on to pursue the fuel issue, Vacuum slide diaphragm had a small tear in it
Old Nov 27, 2013 | 05:34 AM
kino44's Avatar
kino44
Default wont accelerate
is it hitting high RPMs? check you clutch adjustment too could be slipping
Dustin Wicks
Dec 1, 2022 10:22 PM
denisl
Jun 22, 2019 08:02 AM
Surfit
Carburetor Related
Nov 9, 2018 11:20 AM
bg3075
Sep 1, 2014 10:24 PM
ACHALLIE
Shovelhead
Oct 16, 2007 11:18 AM
