Broken Tranny Case
Old Dec 22, 2012 | 07:45 AM
trackadaptor's Avatar
trackadaptor
Cool Broken Tranny Case
So when Harley rolls over a Part Number should be clue 1 there's trouble
Red Line HD Tranny oil , ran Belt 1/4" loose than called out ( old school )
Should have been a simple Output Bearing change, once pressed out it was clear the Tranny case was cracked as well
My Tranny case came from Detroit 1 of 3 in the country I know cuse the Tranny I got from Ariz. came with a broken mouning tab.....
Signs: Shifting harder , Clicking noise -engine off or on rolling ,
50k miles crap wears out.....
Shout out to Peter at: http://www.doublercycles.com/
Took just under 4 weeks waiting for parts was not fun.... The new case is Beffer say good 1/4" in the bearing area...
Like the Clutch hub that failed, I just received a call yesterday the new ones are slowly tricklen in , already went SE Clutch hub route
Oh ya, the Bearing and output gear "6th" was actually rusted together
New Tranny Case $ 359.00 + 3 day air $166
Having "Shirley" home for Christmass Priceless
Old Dec 22, 2012 | 11:15 AM
Hayhoss's Avatar
Hayhoss
Trackadaptor, the bearing and output gear rusted together ?? Moisture inside the tranny, or a Red Line issue? Asking becouse maybe I need to switch from Red Line to another brand ! Thanks, Craig
Old Dec 22, 2012 | 11:43 AM
mkguitar's Avatar
mkguitar
Yeah, how'd all that water get in the tranny case?
even though moisture will settle under the lube, it should have been warmed to the point where it could evaporate out the vent tube
a lot of moisture mixed with the lube will keep the lube from lubricating anything, so no surprise if bearings failed
mike
Old Dec 22, 2012 | 01:03 PM
EasternSP's Avatar
EasternSP
Either a lot of riding in the rain or power washing it and getting water into the vent hose.
Old Dec 22, 2012 | 06:24 PM
trackadaptor
Rusty parts...betting on an assembly issue...sent parts to Harley
Red Line Oil is great stuff, I will never ever change
Water through the Vent Tube: Never used a power washer, not even on my Motocross bikes, Simple green, good cleaning mit, I use a Garden Water Nozzle.... but given that , take a look at your vent hose
Old Dec 23, 2012 | 06:22 PM
leon anthony's Avatar
leon anthony
that sign is about i2 miles from my house
Old Dec 23, 2012 | 08:15 PM
Bruce00's Avatar
Bruce00
That truely sucks....................
wishin ya a speedy recovery
Old Dec 23, 2012 | 08:36 PM
bklynbob's Avatar
bklynbob
Redline is too heavy,like mud doesn't get splashed around,doesn't get into small crevices. it's only good in exrtemely hot weather...................
Aircooled81
18
Jan 13, 2019 06:23 PM
ONEEYE05FLSTC
Mar 25, 2015 08:06 PM
beary
Feb 3, 2015 07:42 PM
supafish
Jun 21, 2013 02:59 PM
trackadaptor
Dec 5, 2012 06:43 PM
