Pushrods through the top
Old Jan 10, 2014 | 05:05 AM
just plain john's Avatar
just plain john
Default Pushrods through the top
I'm assembling parts for a cam swap. I'm reusing the OEM pushrods. I see that the MoCo sells a rocker box wrench. For those that have done it, is it necessary to use it? Obviously the tank will be off, but having never had it off before I don't know what kind of clearances I'll have to work with. Also, someone mentioned a dogbone torque adapter. Again, is it necessary?
Old Jan 10, 2014 | 05:26 AM
Notgrownup's Avatar
Notgrownup
What i was told is you can use a offset wrench... I was told that there was a cheaper option than that dogbone...Just buy a cheap set of wrench from harbor freight...Now i will say the nice thing about the dogbone is it makes it easy to use the torque wrenches...
Old Jan 10, 2014 | 05:35 AM
RoadKing2438's Avatar
RoadKing2438
They make a couple of different tools to make that job easier. Taking the tank off will definitely make it a lot easier. Personally, I have done it without having the tools, and it is a pain in the butt.
Old Jan 10, 2014 | 05:38 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I used standard combination wrenches. Their sizes were sufficient to fit on either my 1/2" or 3/8" torque wrenches. Offset 90 degrees and you don't need to adjust torque values.
Front cylinder was easy, rear not so.
Old Jan 10, 2014 | 05:43 AM
Notgrownup's Avatar
Notgrownup
Draining the tank is the biggest PITA...I have taken mine off so many times now it's ain't nothing but a thing...Unhook the crossover line in front of the tank and plug one side while the other side is draining then i drain the other...Lift the back and Voila... i use Urine bag tubing as i sell it and it's cheap or free for me.
Old Jan 10, 2014 | 05:56 AM
QC's Avatar
QC
I didn't use the dogbones the first time I had mine apart, but I got them for the next time.
Old Jan 10, 2014 | 05:59 AM
just plain john
So not knowing better, what do I need to get?
Old Jan 10, 2014 | 06:00 AM
rick2800's Avatar
rick2800
That would have been handy my crows feet wrench worked also. That tool and the crowsfeet are for torquing to specs.
Old Jan 10, 2014 | 06:03 AM
QC's Avatar
QC
I bought 3 dogbones cuz I couldn't remember: 3/8, 7/16, and 1/2. Do you have ball-end Allen wrenches?
Old Jan 10, 2014 | 06:04 AM
jmpancoast's Avatar
jmpancoast
I have done it without the dogbone. PITA. I will have a dogbone next time I do it. IMO, small investment to simplify things and ensure it is done right.
