Harley will not start in neutral
Old Feb 16, 2014 | 06:53 PM
  #41
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by 09 YELLOWBIRD
Have you tried this?
When the neutral light is on. Push your bike forward with the clutch not engaged. If the bike doesn't move, it's most likely still in gear. Can it maybe in between a gear and neutral, but just enough to have the green H Light on?
Start with the simple stuff first.
YB
Even if it were in gear, as long as the indicator light is on, the starter should engage (the safety system really doesn`t know if the trans is in neutral, it only knows what the neutral switch tells it).
The neutral light is on, which means the neutral switch is sending power to the indicator lamp, and this signal should also be going to the TSM.
The TSM needs a signal from either the neutral switch or the clutch switch in order to allow the starter solenoid to be energized.
The wire that comes from the Neutral switch has two legs, one leg goes to the indicator, the other leg goes to the TSM, that is where the problem probably is. It may be as simple as a bad connection at the TSM.
Originally Posted by themouth!!!
Do these bikes have a neutral safety switch? If so, yours is bad...
The neutral switch is sending the signal to the indicator lamp, so we know it is working.
Old Feb 16, 2014 | 08:17 PM
  #42
Loc_Tite's Avatar
Loc_Tite
Yes, pretty simple. I can imagine the responses if Harleys had a kickstand switch like the metrics use on top of it all.
Old Feb 16, 2014 | 08:31 PM
  #43
stro1965's Avatar
stro1965
Cop bikes do!
Old Feb 16, 2014 | 08:37 PM
  #44
Woodchuck's Avatar
Woodchuck
Originally Posted by Steve Stayton
2010 Road King won't start when in neutral. The neutral light is on. When I pull the clutch In it starts up with no problems. Harley told they have never seen that issue before.
Two options: 1.) Disengage the clutch to start it or 2.) Don't shut it down.
Old Feb 16, 2014 | 08:54 PM
  #45
Dan89FLSTC's Avatar
Dan89FLSTC
They gave you the wrong answer, they have been trained to say:
"They all do that".
Risky Rick
VRSC Models
Jun 5, 2016 04:46 PM
cajun1957a
Apr 18, 2016 06:56 PM
pk54
Jul 28, 2013 07:33 AM
TurkeyRun
Nov 12, 2012 09:44 AM
chardagha
Feb 16, 2011 10:28 AM
