Cam Install
Old Apr 3, 2014 | 10:53 AM
the warden's Avatar
the warden
I don't see any mention of anyone replacing the cam bearings. This is a must when you are changing cams and the proper bearing removal and install tool are also a must for this job. While these engines are pretty simple there are still a few speciality tools required over and above a handful of basic hand tools.
Old Apr 3, 2014 | 10:56 AM
mathew2172's Avatar
mathew2172
Well yes you need to change the bearings. He bought the bearing removal and install tool. Works slick as snot!
Old Apr 5, 2014 | 12:27 PM
sanman4ever's Avatar
sanman4ever
Just completed the project late last night / this morning. Started right up and was making some ticking / knocking but settled down after getting to temperature. Idled good too.
I used FM pushrods with the OEM pushrod tubes. What a pain in the *** getting the push tube clips back on.
Also installed the Axtell oil bypass w/ zippers tensioners
Old Apr 6, 2014 | 04:50 PM
leaddog11's Avatar
leaddog11
plan to do mine soon
Old Apr 6, 2014 | 05:15 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by sanman4ever
I got the OEM gaskets....research said those are the best to use.
good move.. or cometic.
Turret_plug
EVO
50
May 31, 2016 11:41 AM
steelpony16
Sep 27, 2013 03:58 PM
rdc401
Dec 28, 2011 12:23 PM
Bowhunter61
Feb 20, 2011 03:59 PM
18BKLR
Jul 31, 2010 11:24 AM
