Road King Lowering
Old Jul 14, 2014 | 04:37 PM
sallen's Avatar
sallen
4th Gear
Default Road King Lowering
I just traded in my Super Glide Custom for a Road King (like 1.5 days ago) I am loving the RK, but I think I would feel more comfortable if I lower it. I am flat footed at a stop, but would like a little bend in my legs when backing up. Looking for suggestions... Also, do I have to lower both the front & back? Thanks for any input
Old Jul 14, 2014 | 04:50 PM
mkguitar's Avatar
mkguitar
many of us lower the rear an inch or more
there are drawbacks in lost suspension travel or ride quality...bottoming out or the tire contacting the inner fender.
lowering blocks from $25 on ebay
some use shorter shocks such as on the streetglide ( about $150 used- check classifieds) or premium priced ($500+) shocks are available which may be better tuned to your needs.
the rear can be lowered without lowering the front- but NOT viceversa
Mike
Old Jul 14, 2014 | 04:54 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Seats can also be shaved, dropping you.
Old Jul 14, 2014 | 05:06 PM
Raddazzz's Avatar
Raddazzz
I had my stock ultra shocks shortened an inch, ride was very firm. Seemed like after a year the shocks kinda blew out and developed a leak. I went back to a set of stock shocks with the lowering blocks and the ride is much better with no rubbing. Wished I had went this route from the beginning. I left the forks stock.
Old Jul 15, 2014 | 03:15 AM
crimson13's Avatar
crimson13
Which lowering blocks did you use?
Old Jul 15, 2014 | 04:32 AM
RollTideRoadGlide's Avatar
RollTideRoadGlide
Was their any problems scraping the ground on turns?
Old Jul 15, 2014 | 07:43 AM
RKZen's Avatar
RKZen
I changed out the stock shocks with the HD Profile Lows front and rear when I got my bike. Had the seat modified as well. I ride mostly solo, so it's been good for now.
Old Jul 15, 2014 | 08:12 AM
painey's Avatar
painey
I used Bitchin Baggers rear shocks to lower my RK by about 1.5in(I only have a 29" seam) and now about to fit a 23inch front wheel so will be adding a set Progressive drop in lowered springs to get the bike sitting level.
Old Jul 15, 2014 | 08:39 AM
crawlgsx's Avatar
crawlgsx
I just bought a 2010 RK and lowered just the rear, made a HUGE difference.
You can get the lowering brackets for ~$30 or less and its easy as pie to install.
http://www.ebay.com/itm/330685967042...84.m1497.l2649
Do have to be a little more careful when pulling in and out of driveways (I have the longer bags as well) but worth it. I still have plenty of clearance for cornering. I went with a 2" drop for now but my plan is to drop the front ~1" later and bring the back up 1".
I didn't notice any ride quality difference but I ride solo @ 180lbs. I run real low air pressure in the shocks.
Old Jul 15, 2014 | 12:46 PM
sallen's Avatar
sallen
4th Gear
Thanks for advice!
millcreekdr
Apr 17, 2019 01:53 PM
NowgFstCat
Feb 13, 2015 08:04 AM
t_rick37
Dec 17, 2014 03:50 AM
blockzilla
Dec 8, 2011 10:13 PM
roadkingdave
Mar 9, 2007 10:15 PM
