2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Jul 4, 2022 | 06:45 AM
  #1361
Murfie Smurf's Avatar
Murfie Smurf
HI Mate
I did short shots on my 2019 and used the FP3 with no problems at all... if you get issues with the downloaded map then you can auto-tune to sort out any glitches.
Standard air filter is High flow so should be ok but can replace with K& N if you fancy it and possibly more airflow but not convinced
Old Jul 9, 2022 | 03:52 PM
  #1362
jmatero's Avatar
jmatero
Has anyone had luck locating high quality black caps for the riser bolts and front forks? Somebody on eBay was making some nice ones a couple years ago but no longer.
Old Jul 9, 2022 | 07:13 PM
  #1363
fatbob1733's Avatar
fatbob1733
Stage I
Default Leaking Rear Shock???
Anybody ever notice fluid on the shock ****? 900 miles on this bike and I noticed this when I got to work yesterday. It’s not alot but I’m wondering where it came from. I don’t see anything around the rear head or see a leak that could drip backwards. I’m about to take the seat and side cover off to keep looking but I thought I’d ask. I’ll take it in and let HD look at it under warranty but wanted to see if it was a known issue
Old Jul 11, 2022 | 07:32 AM
  #1364
Murfie Smurf
My bike has decided to do something similar..
Only advice I have been given is a best guess that its spray from the air cleaner, although the air cleaner is bone dry.
Someone else did an identical post in the Facebook 2018+ FatBob group and neither of us got any replies from people haveing the same issue.
Advise please if you have had this issue your self or dealt with it.
Old Jul 14, 2022 | 06:45 PM
  #1365
SCarty's Avatar
SCarty
My Fat Bob
Old Jul 14, 2022 | 06:54 PM
  #1366
SCarty's Avatar
SCarty
Old Jul 15, 2022 | 02:20 AM
  #1367
Murfie Smurf
Hi Mate,
I think you and I are following each other around the forums and Facebook groups.
Had loads of good advise about mist from the oil breather pipe in the air cleaner from the M* engine section but on further leakage and inspection this morning I think we are in the same boat and it appears to be the rear shock around the shock adjuster.
Have you had any more information and have you spoken to Harley under your warranty as mine is over two year so cant take it to them with out a big bill so the more i know first the better...
Old Jul 15, 2022 | 08:28 AM
  #1368
Murfie Smurf
Looks like it is the shock mate, and its a non serviceable item so not fixable so get yours done under warranty quick sharp.
Mine on the other had is about to become costly...
Old Jul 15, 2022 | 03:41 PM
  #1369
Calif Fat Bob's Avatar
Calif Fat Bob
Originally Posted by SCarty
My Fat Bob
@SCarty What seat is that on your Fat Bob? Looks great. Is it more comfortable than the stocker I assume?
Also what skid plate is that up front??
Old Jul 15, 2022 | 04:43 PM
  #1370
SCarty's Avatar
SCarty
It's a Saddlemen Profiler seat and so far I like it and the Skid plate is made by Speed merchant
