Oh yeah, head work time
Old Feb 26, 2016 | 12:17 PM
  #161
mattVA's Avatar
mattVA
That sounds real healthy Robby. Congratulations. I like the lope on those cams at idle too. Good work.
Old Feb 26, 2016 | 01:03 PM
  #162
adm's Avatar
adm
Looking good there Robby - now go and enjoy it!
Old Feb 26, 2016 | 01:49 PM
  #163
Frédéric CM's Avatar
Frédéric CM
nice f***in sound
looks like it will be fun to ride !
Old Feb 26, 2016 | 01:51 PM
  #164
HD Pilot's Avatar
HD Pilot
Originally Posted by robbyville
Thanks! Can't wait to get the dyno scheduled. Think I can open it up a bit after a few short rides?
Congrats Robby! So, on the pr readjustment, did you do anything do anything different from the first time? Seems to sound great now.
I am in the camp of not babying it - dont let the engine get hot, don't drone around at the same rpms, but ride it up to at least 5000 rpms if you want.
Just what I did anyway...
Old Feb 26, 2016 | 01:53 PM
  #165
monster715's Avatar
monster715
Hell yea good work. That sounds real nice, choppy idle, I like it. I know you haven't ridden it very far but could you instantly feel the increased throttle response?
Old Feb 26, 2016 | 03:41 PM
  #166
robbyville's Avatar
robbyville
So where to start, how about
MAMMA MIA!
"Had" to go out and visit an install we're working on. Took it out for a few miles on Interstate, then some normal Palm Desert traffic. It's over 80 degrees right now so it got warm pretty quickly triggering the oil cooler.
I'm not sure how best to express it, whether it's the current tune, the larger throttle body (which I adjusted far better than the last time when I changed my grips), the heads, the cams, or just that I haven't been on the bike for two weeks. But everything just felt absolutely incredible. I don't know that the bike has the abrupt torque curve that it seemed to before, but it rolls so much smoother and keeps on trucking.
Not that I ran out of torque or power before given my riding style but it seemed maybe a little herky jerky. Driving today on the interstate with no cross winds I wound it up to 90mph both quickly and smoothly.
Dunno, but it feels like a completely new bike, and an awesome one, but maybe it's all in my head justifying the expense... nah
Old Feb 26, 2016 | 05:28 PM
  #167
mirrmu's Avatar
mirrmu
good stuff robbyville,
with the tune you have a the moment if would just check the plugs after a good ride to see that they not covered in black soot or white lean, anything in between you good to roll until dyno shop
Old Feb 26, 2016 | 05:46 PM
  #168
robbyville's Avatar
robbyville
Thanks and will do, just checked the error codes and it does say both cylinders are running rich. But once I stop auto tuning shouldn't that be fixed?
This is my first experience with the PV2, I know how to access the map and such but if I do need to lean it out a bit what's my best method?
Sorry, I know this is probably somewhere in the big PV thread.
Old Feb 26, 2016 | 06:11 PM
  #169
mirrmu's Avatar
mirrmu
i would of kept original tune and increased the front and rear VE tables by 4-5pts globally
basic autotune runs bike at 14.6:1 air fuel ratio and creates a VE model for your engine
this is stoich, whats considered optimum burn, not rich not lean, although many feel its lean and they start to richen up for a more powerful and cooler motor
if you get that code and carbon fouled plugs with normal riding (not while autotuning) then i would look at changing that map
Old Feb 26, 2016 | 06:19 PM
  #170
adm's Avatar
adm
Best plan (IMHO) is to go and ride it "normally" in autotune. Do it a bunch of times, and every time, load the new learned map into the ECU, then next time autotune that. It should dial in pretty quick. I normally use "cap" rather than "scale" on the learned values - seems to work OK.
Don't worry about all the cells you don't hit in normal riding as they aren't really that important anyway. Yeah - make sure "normal" riding hits the WOT zones you probably like!
You can also clear the error codes on the PV - then go ride again and see if they crop up again. There have probably been a few thrown given that you worked on the motor. Clear them all and then see if you have any new ones after a good ride...
